alternator splash shield pic request
Old Oct 9, 2022 | 08:50 PM
msalander's Avatar
msalander
Hello all! I have a 1977 F100. Does anyone have a picture of a correctly installed alternator splash shield? A view from up top would be great, but a variety of pictures would be even greater! I would like to install mine the right way before winter. Thanks so much!
Old Oct 9, 2022 | 08:55 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I have NEVER seen a splash shield on a 73-79 Ford truck. So some pictures will be interesting.
Old Oct 9, 2022 | 09:16 PM
msalander's Avatar
msalander
I found this picture online, but I can't make sense of it. The plastic "push pins" go up from underneath???
Old Oct 9, 2022 | 10:04 PM
dlburch's Avatar
dlburch
looks like that pic is upside down. Not sure if this helps...FYI, the '77 and up splash shield is different...
Old Oct 9, 2022 | 10:40 PM
77&79F250's Avatar
77&79F250
Cool, like I said I have never seen one.
Old Oct 9, 2022 | 10:55 PM
msalander's Avatar
msalander
ok thanks...reading your chart, in 73/74 these shields were galvanized steel or plastic. In 75 they switched to rubber. I'm assuming they all installed in a similar fashion. Sorry about the picture I posted. I found it online. I too think it's upside down which is why I couldn't figure it out initially. The shield I bought is rubber. It looks like (according to your diagram) the tabs fold down and I assume the plastic pins go in from the top. Hopefully, I can figure it out and do it right. Thanks for the pics. I hope other pics are posted by other members.
Old Oct 10, 2022 | 09:51 AM
5851a's Avatar
5851a
My 78 Bronco had one, but I think they are different than 2wd.
Old Oct 10, 2022 | 10:03 AM
Yamhill Ranger's Avatar
Yamhill Ranger
I was thinking....splash shield? I've never seen a splash shield?.... but then- dlburch called it with the upside down photo.
And then I realise I actually still have one on my truck and it never really registered!
I see one of my attaching holes is torn....i'll have to get to fixin that, although I'm not sure that the shield does a whole lot. Maybe cuts wheel splash a bit.
This is on a 77 RWD 460
Old Oct 10, 2022 | 01:01 PM
msalander's Avatar
msalander
Thanks for pic, Yamhill! I see two holes. Is the third hole hidden closer to the front or farther back out of the view of the picture?
Old Oct 10, 2022 | 01:13 PM
Yamhill Ranger
you're welcome. Yeah, wasn't the best picture. The third mounting position is under the cold air intake (toward the front). You might be able to source the plastic retaining clips from AMK. I doubt that they'll be listed for the truck, but they have a lot of Ford fasteners that cross over from the muscle cars.
Old Oct 10, 2022 | 01:18 PM
Yamhill Ranger
better yet....these look like the same part number as listed above (for the pins).
https://www.ebay.com/itm/174425371158
Old Oct 10, 2022 | 02:22 PM
msalander's Avatar
msalander
Ok thanks so much! I have pins that came with the shield, but I don't know if they're exactly correct. I have the same cold air intake on my '77 Custom so I'll move it to find the forwardmost hole. Thanks again!
yankeerebel
Oct 29, 2016 07:41 PM
bailegb
Mar 19, 2010 08:52 AM
Paso1
Jan 30, 2009 03:43 PM
58f100rat
May 12, 2008 07:52 AM
z 97ford1
1997 - 2003 F150
Aug 24, 2003 07:53 AM
