2022 upfitter switch question
Old Oct 3, 2022 | 07:33 AM
Mx113's Avatar
Mx113
Tomorrow, I am installing a fuel transfer tank in a new 2022 F350. I would like to run the power for the 15 gpm pump to an upfitter switch to hopefully avoid any fuel theft. My question is, which switches will work when the truck is not running and the key is not in the ignition? Any help would be appreciated.
Old Oct 3, 2022 | 08:56 AM
thatxjguy's Avatar
thatxjguy
5 and 6. And based on the information below, it’s already fused too.
Old Oct 3, 2022 | 09:04 AM
Mx113's Avatar
Mx113
Thank you sir !
Old Oct 3, 2022 | 10:49 AM
chadstickpoindexter's Avatar
chadstickpoindexter
Yep, 5 & 6. But you will need to switch it in the fuse box to make them always hot.
Old Oct 3, 2022 | 01:29 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
5 and 6 are also much higher amp rated, bigger relays and fuses for them.
smithm31
Apr 17, 2016 10:18 PM
VannerDude
Feb 22, 2015 01:54 PM
rebelyell618
May 4, 2008 07:46 PM
Leonard Bode
May 2, 2004 07:09 PM
rangerman9000
1983 - 2012 Ranger & B-Series
Oct 21, 2003 11:38 AM
