My buddy has a early99 superduty with a PS and it never got more than 10MPG since new. The puzzling thing is it does this empty or with 6000lbs on it. It still gets 10MPG either way. Nobody can figure this out. The dealer says the truck is fine!
Change the Air filter to a performance type and change the downpipe to a 3.5". For about $200.00 this is a good start. I also have a 97 with the same gears, I found a big improvement doing this, Both mileage and power.
THANKS ILL SEE IF SANTA CAN SQUEEZE THE DOWN PIPE IN HIS BAG.IM A MOTORCYCLE TECHNICIAN-FABRICATOR SO IM GONNA TRY TO MAKE MY OWN FILTER SET UP.CANT BE THAT HARD.IVE FOUND OUT YESTERDAY THAT MY EXHAUST VAVLE ISNT WORKING CORRECTLY SO ILL GET THAT FIXED AND GO FROM THERE.
you might also want to try to clean the fuel regulator screen on the driver's side of the fuel bowl and clean out the crud from the bottom if there is any. it might help some
