power steering fluid question
Old Aug 25, 2022 | 06:20 AM
steff503's Avatar
steff503
2005 sport trac has a leak in the power steering fluid. Can that cause it to have a severe wobble and how?
I have had many cars and trucks that lost all fluid and that never happened. I have bypassed the power steering pump in cars and never a wobble.
This truck wobbles so bad that I am afraid to travel more than a few miles.
I have changed the tie rod ends, gotten new tires, alignment and next is shocks, but can it be the leak?
Old Aug 26, 2022 | 12:43 PM
shorod's Avatar
shorod
I suppose if the fluid level is low enough that there is air in the system, and the pump is trying to compress and pump the air, it will have intermittent power assist and maybe the pressure differential could cause the steering rack to wander a bit. If you've properly checked all other suspension and steering components along with the tires (tread and inflation) and they all check out as okay, then alignment and fixing the known issue with the power steering system is the next logical step.
On my 1995 Bronco, I recently replaced the power steering pump because it was whining even though the fluid level was correct. It had the noise since I bought it so I'm not sure if the type was correct or not. Prior to replacing the noisy pump it was a bit sketchy to drive. I had assumed several of the bushings in the twin torque tube front suspension were in need of replacement, even though everything seemed tight. After installing and bleeding the new pump, the steering felt MUCH better, and is probably as good as it's going to get with slightly oversized tires.
-Rod
Old Aug 26, 2022 | 01:00 PM
steff503's Avatar
steff503
Would it cause an issue if it was traveling straight ?
Old Aug 26, 2022 | 08:24 PM
shorod's Avatar
shorod
Possibly. On the Bronco it seemed to wander, and there was a lot of travel in the steering wheel to correct little imperfections in the road.
Are you contemplating whether or not to keep the truck or get rid of it because of the leak in the power steering? Do you know what part of the power steering system is leaking? If you plan to keep the truck, you should plan to fix the bad part. The longer you use the truck with a bad part and low fluid level, the more likely you are to do additional damage to the remainder of the power steering system.
-Rod
Old Sep 1, 2022 | 05:45 PM
My4Fordtrucks's Avatar
My4Fordtrucks
How are the ball joints?
Originally Posted by shorod
twin torque tube front suspension….. is probably as good as it's going to get with slightly oversized tires.
-Rod
TTB —> twin traction beam front suspension
That much play in the steering with everything else being good it is most likely slop in the steering gear.
1992FordF150Custom
Jul 6, 2014 03:31 PM
cardiacjohn
Sep 14, 2013 12:55 PM
clintusaf
26
Nov 28, 2010 08:13 PM
crashed13
21
Oct 3, 2005 03:56 PM
