carter 1bbl
Old Nov 10, 2003 | 08:04 PM
msinger's Avatar
msinger
carter 1bbl
vacuum, 1972 F-100 vacuum diagram , also choke tube replacement carter 1bbl
Old Nov 10, 2003 | 08:17 PM
MudinMan19704x4's Avatar
MudinMan19704x4
are you asking for a diagram or what?
Old Nov 11, 2003 | 03:08 AM
willowbilly3's Avatar
willowbilly3
Vacuum diagram? It has one vac. hose that goes to the carb for the vacuum advance on the dist. You shouldn't need a diagram to get that on. Any parts store should have a choke stove repair kit. Look in the Help selection. I also have put an electric chole on my 72 300-6. You will still need the heat tube. Wire the choke-stat to the S wire on the alternator.
Old Nov 11, 2003 | 01:46 PM
msinger's Avatar
msinger
heat tube for carter 1bbl, could someone tell me where hole is located in manifold, can it be installed without removing manifold
Old Nov 11, 2003 | 03:45 PM
willowbilly3
Looking down from the top you should see it on the #5 exhaust runner betweeb the valve cover and the intake manifold. You shouldn't have to remove the manifold but remember that there is another hose off the bottom of the manifold that is the intake side of the heat stove and it had a section of pipe with a hose going to the top of the carb right under the air cleaner. Your heat stove has a small amount of vacuum to it to suck the hot air in and the hose from the bottom of the manifold allows it to draw clean air that has come through the air filter. It will work without this but you will be allowing dirty air to enter the carburator.
Old Nov 11, 2003 | 08:34 PM
msinger's Avatar
msinger
thanks for the information
