it has to be to good to be true
well its plane hot here in arkansas
and maybe i might put air in my 64 100
i see ebay has 12volt compressors for sale? thay cant work can Thay ?? the alternator caint keep up
or not put enough amps to run ome
also what are you guys running for ac have a v belt system on my 302 engine
thanks mike
Vintage Air makes a complete kit that has everything you need, and made to fit your truck. Very good quality and very well engineered.
It is not cheap, but piecing all the stuff needed would be a major task.
What he said +1. 3 years ago the Vintage Air was $1500. Probably more pricey with inflation and the COVID stupidity.
In 2021, when I first started pricing the kit out, it was just under 1600. I paid just under $2000 at the end of April 2022.
Vintage Air also had a lead time of 12-14 weeks. They sent me to an outfit called Affordable Street Rods. They had a lot of the stuff in stock, but not all. But I had everything in four weeks. Plus I saved a couple hundred bucks! Top notch outfit to deal with!
