2013 Fuel Gauge Problem
Old Jun 16, 2022 | 07:05 AM
DH166's Avatar
DH166
4wd High
Fuel gauge on my 2013 5.0 reads inaccurately, and it does so in different ways. Depending on the day, it tends to peg out at either full or empty. However, it will rarely give an accurate reading. I replaced the whole pump assembly. No dice. I have no check engine light on. Yesterday, I dropped the tank and pulled the assembly to check it again. Rheostat responds as it should when I moved the arm and tested on the multimeter, and I put the pump in a bucket and filled it with gas and the float arm is free. It isn't bent or impeded in any way. I tested the connector to the sending unit with a variable resistor and it gives me readings on the gauge at the dash. I'm at a loss. A couple of days ago, before I dropped the tank, I crawled underneath and pulled around on the wiring harness. The next startup resulted in an accurate reading that lasted briefly. That would seem to indicate a loose connection, but the aforementioned tests would seem to rule that out. If I'm plugging into the connector where it joins the sending unit at the tank and getting a good reading, what other wiring is there to check? Any help is appreciated.
Old Jun 16, 2022 | 09:03 AM
RLXXI's Avatar
RLXXI
Check the fluid baffle in the tank to see if it's loose and moving around.
jnealhicks
Jul 10, 2019 03:29 PM
Bootlegger's Deluxe
26
Jul 1, 2017 12:05 PM
maple sapper
Apr 12, 2012 10:11 PM
v8xploder
1978 - 1996 Big Bronco
Apr 27, 2009 10:49 AM
evanderson
May 6, 2003 12:09 PM
