Twin I-Beams vs. A-arms
Ford got rid of the TTB because people couldn't keep tires on the front of their trucks. It would wear a set out twice as fast as the A-arm setup. I had one, and it was a pain. Had to rotate tires twice a month seemed like. Then I bought a GM with the A-arm setup. Even though the truck was GM junk, the A-arm setup immediately got my attention. Smoother ride, easier on tires, helped in braking, and I tortured it off-road and never had a minutes trouble. Suspension is definitely one area that GM had a HUGE advantage in for almost a decade.
the twin I beam is a favorite for desert racers and is easier to lift then the tradional A-arm set up. as for the TTB comments, i keep my tires regularly rotated and i haven't had a lick of trouble keeping tires on mine. even now with it out of allignment the tires are wearing good and i thrash it off-road.
In 2000 I completely redid the TTB front end on my 84 4wd: coil springs, shocks, bushings, balljoints, tierod ends, the whole deal. I put a brand new set of 31x10.50s on a year ago, rotated them once since then; and tire wear has not been a problem. While it cost me nearly 1000 dollars to redo the frontend, it has payed for its self many times over already. I beat on it pretty hard off road and still have no serious alignment problems. I love the TTB it seems to have a lot more travel than the A arm set up, and the strength is not even comparable. U-joints versus CVs? I'll take strength over smoothness any day of the week. Not only that A arm frontends don't allow the installation of lockout hubs.
can,t say as i,ve ever had a problem with my front tires wearing out, cant keep rear tires on my f-150... surprise surprise it's a 5.0
as for the other trucks my friend had a 2001 dacota, mind you he thrashed it, but the whole front differential fell out on the ground while off roading. completely disconnected. Took the truck to dodge, 1 year old, 20000k and they said he overtorked it. with a 3.9 and cancelled his warrenty
Originally posted by 92f150I6
Not getting on your case here, but, I disagree. The old GM's (and current ones) Eat more front end parts like ball joints, idler arms, and toe rod ends than any other vehicle I work on. I never so much as rotated the front tires on my 92 f150 in the year and a half I owned it, they wore perfectly even, and the truck tracked straight down the road. ALso, the ride of my truc was a lot less harsh than any Chevy truck I have ever riddenin or worked on. The Twin I/ tracton beam is the best, independant suspencion that is out there IMO. Probably the main factor I bought an F250 SD vs. the 150 is due to the front suspension. I absolutely did not want the much weaker front end.
Whenever this debate comes up I read about how weak the a-arm setup is, then a bunch of examples of broken chevy's and dodges. Everybody says the CV joints are weak, but I don't remember reading about any breaking. Also I don't read about much tire eating trouble with the a-arms and I never read about an a-arm (or frame connection points) actually breaking. I think both designs are pretty good and have some pros and cons. I really like the Twin I-Beam 2wd's, I have an econoline and a pal of mine has a 150 and the front ends on them are great. But I think the handling with the a-arm is better. And everytime this comes up and people say the a-arm is weak, they use chevy's or dodges as the examples. For heavy off-roading I'd want a solid axle over either of them. anybody who knows of a FORD a-arm that ripped loose, let's see some pics...
I've owned 3 Rangers with 2wd and the twin I beam. I liked it, really tough suspension, and hard to knock out of alignment. Didn't chew up tires too bad, except for the last Ranger. For some reason, that truck was really tough on tires, both front and rear, so I can't blame the twin I beams. Maybe I should have rotated them more often, but it's too much trouble sometimes! My '03 F150 2wd has the A-arms, seems to be good too. But for off road, can't beat the solid front axle!
But,
The aluminum front differential housing is weak compared to cast iron, and really have no place in a full size truck. The dodge 1500 4X4 has only been IFS since the 2002 model, and really haven' t been around long enough to tell if they will last.
