How do you replace a sun visor arm bracket?
Old May 23, 2022 | 10:46 PM
rickm15752's Avatar
rickm15752
1989 Ford E-150 Cargo Van
The driver's sun visor arm bracket broke off where it attaches to the body of the vehicle. I obtained a replacement arm bracket and now need to figure out how to remove the old arm and insert the new arm into the visor. The arm is about 7 or 8 inches and looks like a big pin with some flat points. I'm wondering if I need to open the vinyl sun visor to accomplish this task. I 'd hate to remove the stitching to open the thing up just to see inside. I tried pulling the old arm out of the visor, but it's holding tight. If anyone has worked on these or can refer me to some information that would be quite helpful. Thanks.
Old May 24, 2022 | 04:40 AM
JWA's Avatar
JWA
I would have obtained the complete visor intact and simply replaced it. Not really sure how to replace just the support/pivot rod.
Old May 24, 2022 | 08:51 AM
rickm15752's Avatar
rickm15752
JWA,
Unfortunately, the sun visor is out of production now. I tried to locate a complete visor through salvage yards and exhaustive searches online, but no luck. The sun visor itself is in good condition, just the arm bracket is not. I may call a few upholstery shops to see if they can help. Maybe resew the visor after I remove the stitching and install the new arm.
Old May 24, 2022 | 09:21 AM
rickm15752's Avatar
rickm15752
I found a Youtube video that shows a very similar sun visor, only mine is vinyl and does not have a mirror. So, I think I'll remove the stitching, open the visor like shown in the video, replace the arm bracket and have an upholstery shop sew it back together.
Old May 25, 2022 | 06:53 AM
manicmechanic007's Avatar
manicmechanic007
They just twist and pull off of there
The "D's" are there just to help get the visor off the ledges that hold it tight
You might need to destroy a wrecking yard one to see what there is inside
Then you will understand what needs to be done to remove the visor from the rod
Good luck
cedar river rat
Mar 23, 2012 11:18 AM
smokeyb97
37
Apr 16, 2011 10:21 AM
cheetoh
Nov 16, 2004 05:42 AM
