Tire pressure
Old May 8, 2022 | 07:54 PM
3twinridges's Avatar
3twinridges
Tire pressure
The rating on the sidewall of our Firestone bias ply tires says 32 psi max. They are staying at that pressure pretty consistently cold. I went for a short drive tonight, maybe 10 miles and then measured them, they were at 35 on the front and 33 on the back. Should the pressure be set at ambient temp or after driving/warm?
JB
Old May 8, 2022 | 08:51 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Tire pressure is set at tire cold.
I would also go as far as saying, if you want the correct pressure you need to know what the axle weight is and set presser by weight based on the tire load chart, not by max psi on the sidewall.
If you have a pressure in the manual it is usually based on max payload per axle.
Old May 9, 2022 | 08:12 AM
ReForder's Avatar
ReForder
Tire pressure is always set cold. If you've driven the car more than 2 miles you should let them cool down for 1-2 hours before you check them again. It may not seem like a big deal but once you get heat into the tires you shouldn't be adjusting pressure unless it's an emergency.
I would agree with Jimmy BUT you have to make sure the tires currently on the car/truck are the correct load rating for the application if you plan on using the tire load chart for a specific vehicle.
Sorry to belabor the point.
Old May 9, 2022 | 12:14 PM
Bob Ingram's Avatar
Bob Ingram
The owners manual says 28lbs for an F1
Old May 9, 2022 | 12:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That seems much more reasonable for bias plies. 32 is the maximum, not the recommended pressure.
Old May 15, 2022 | 01:10 PM
3twinridges
Thanks guys. I drove the truck today set at 28 and it was perfect. Drove awesome. I think at 32, after some heat starts in the tires, I was driving on balloons. I think I have fine tuned everything so that it runs like a top, I even hit the interstate for a few miles and hit 70. Appreciate the advice.
JB
Old May 16, 2022 | 09:12 AM
Bob Ingram's Avatar
Bob Ingram
JB
RTFM
Read the Ford Manual
GM in a Ford
Jan 16, 2022 08:01 PM
DND58
All Things Towing
Apr 20, 2011 08:13 PM
mjunk1
1997 - 2003 F150
15
May 19, 2008 09:08 PM
the Goat
Dec 2, 2007 03:18 PM
pezley69
1978 - 1996 Big Bronco
Apr 1, 2003 01:52 PM
