Ball joint press?
Old May 4, 2022 | 04:36 PM
Hyakkimaru's Avatar
Hyakkimaru
Ball joint press?
Does anybody have a example of what ball joint press kit I need to get to put my upper and lower ball joints on? I got my xrf ball joints in this afternoon. I was thinking to get the master kit from advanced. But I've heard some folks say that not all kids come with what you need for these trucks. Any advice?
Old May 4, 2022 | 06:12 PM
Walleye Hunter's Avatar
Walleye Hunter
I borrowed a kit from Poop Boys and had to fudge it somehow but I forget how. I have a good collection of 'stuff' out there so I was able to get by.
Old May 4, 2022 | 06:45 PM
Hyakkimaru's Avatar
Hyakkimaru
Well, I got the biggest baddest puller around here from an auto parts store that I could get and it was not big enough and I had to get by with all kinds of stuff that was not supposed to be used but I got one side done. What are the torque specs for these? My computer is still down so I cannot use the service manual that Sous was kind enough to give me.
Old May 4, 2022 | 06:48 PM
FordTruckNoob's Avatar
FordTruckNoob
I have been using the one from HF with great success. You will need the adapters also.
https://www.harborfreight.com/ball-j...les-63279.html
https://www.harborfreight.com/master...-pc-63725.html
Old May 4, 2022 | 06:51 PM
PriusLover's Avatar
PriusLover
Amazon Amazon
This is the one I've used. Whatever you get just make sure it's made in Taiwan at least.
Old May 4, 2022 | 06:52 PM
FordTruckNoob
Weird. I can't edit my post to add the document with the torque specs. Here you go.
Old May 4, 2022 | 09:12 PM
Hyakkimaru's Avatar
Hyakkimaru
Thanks for all the help guys. Just got done putting my mounting bracket and caliper back on the passenger side. All I got to do is put that tire on and I'm done. Then it's off to the alignment shop tomorrow. Actually first is to head to the auto parts store and return this ball joint press that was $280 up front to rent of course you get all of that back but, it was missing parts when we got it. That being said, they better not accuse me of losing those parts. I will be a mad son of a gun. All in all, ball joints didn't seem to be that hard on this truck and didn't take me that long. Although I will say doing all those big torque numbers in tight places has sure made my back go to hurting with all the problems that it has and my carpal tunnel in my hands go to hurting. I feel like I've been beat up but it didn't seem that hard. All in all, I hope this fixes my weird tire wearing issue. It wore down good used tires in a month so there was definitely some problems and when I jacked the truck up you could see the tire move outwards a good inch or inch and a half. All brand new million mile warranty xrf installed so hopefully I won't have any problems for a long time to come. Now all I have to do is get new hubs so I can put on my new rotors and calipers. Again, thanks guys for the help!
Old May 5, 2022 | 09:06 AM
Hyakkimaru's Avatar
Hyakkimaru
My ball joints were pretty bad. Here's a little video. Glad I got them changed out now I just need to get an alignment done
https://youtu.be/NvuyYDez0Vc
Old May 5, 2022 | 02:05 PM
z31freakify's Avatar
z31freakify
When posting links from U tube press the "share" icon then press copy link, then paste it on your FTE post, your linked video will post as video format.
Old May 5, 2022 | 02:32 PM
Hyakkimaru's Avatar
Hyakkimaru
That's how I did it and have always done it though
I'm not sure. Maybe your on computer and I'm on Android?
Old May 5, 2022 | 02:36 PM
Hyakkimaru's Avatar
Hyakkimaru
Definitely need and alignment. My truck seems to track straight but it seems to sway back and forth when driving. Then again my steering was so stiff before it was ridiculous so maybe I'm overcompensating while steering and doing it myself. Not.sure but I have a new Ford tie rod adjusting sleeve on the way to put on before taking it to the allignment shop. The best shop I know of and have been recommended to, quoted 110 dollars to change the sleeve and 80 on top to line the front end up.
Old May 5, 2022 | 03:21 PM
FordTruckNoob
Sounds like you need more toe-in.
Old May 5, 2022 | 03:39 PM
z31freakify
I don't own a computer🧐
Old May 5, 2022 | 04:03 PM
Hyakkimaru's Avatar
Hyakkimaru
I checked that this morning after I found myself swaying and was 1 inch toed in. I adjusted it out a little bit. I'll check again this afternoon and see if anything is different. Thanks
Old May 5, 2022 | 04:05 PM
Hyakkimaru's Avatar
Hyakkimaru
Oh. I'm not sure then. I always post links by clicking the share button the copying the link then pasting it. Always have.
