Sponsored by: Real Truck
2004 F350 p0455 evap code problems
Old Apr 26, 2022 | 02:29 PM
ASeab2230's Avatar
ASeab2230
Good Afternoon
I just recently bought a 2004 f350 5.4L gas and not long after driving it it threw a p0455 evap code. Ever since then, the truck makes a loud drum noise every couple seconds at idle and it shakes the truck. it is also causing me to sputter when I am accelerating and it certainly not at full power. I have looked up many of the easy solutions and I replaced the fuel cap just in case and even the canister purge valve and no luck. From what I can see there is not an ounce of fuel leaking out of anywhere. The only thing I noticed is to small nicks in the two hoses coming off the top of the fuel pump, no fuel is leaking out. Any ideas?????
Old Apr 28, 2022 | 08:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE!
Sounds like maybe your charcoal canister is clogged.
Old Apr 28, 2022 | 12:10 PM
Mike1's Avatar
Mike1
Maybe your vent valve isn't operating? You should probably hook and and OBD scanner and do some live data., But here's a video for the Vent valve. Good luck.
Ortenfelter
6.7L Power Stroke Diesel
Dec 9, 2017 01:02 PM
TheK-Man
Mar 19, 2017 10:42 PM
TruckoffFord
Jun 10, 2015 09:12 PM
JACKUS2
3.8 & 4.2L V6
Dec 5, 2011 09:25 AM
wjlaisure
Modular V8 (4.6L, 5.4L)
Sep 27, 2010 09:44 PM
