Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1954 C900 COE decode
Old Apr 21, 2022 | 10:15 PM
gjinc's Avatar
gjinc
HI, is the 5th digit the year? C90K4H
27000 116 151 3600
5DIR 717-977 R 25AC1-1008
Old Apr 21, 2022 | 11:45 PM
85e150's Avatar
85e150
27000 116 151 3600
Welcome to FTE.
No, not on an 11 digit VIN. The year is determined by the last digits of the vin, unless that is a 17 digit that you have shortened front and back. Or earlier 11 digit VIN..... (EDIT, SEE BELOW)
Post a picture of the plate for a decode.
Old Apr 22, 2022 | 05:36 AM
gjinc's Avatar
gjinc
Think I found my answer, this chart only goes to the C600 but would figure it to be the same thru the c900
Does not show what the "K" engine code would be.
Thanks
Old Apr 22, 2022 | 09:38 AM
85e150's Avatar
85e150
That guide only works for the years shown. Post the picture of the plate or at least the whole VIN.
Old Apr 22, 2022 | 02:17 PM
85e150's Avatar
85e150
Looked at this again and see my errors.
C90 = '54-'56 C900 cab forward, the predecessor to the tilt cab C series
K = 317 CID Lincoln Y-block V8
4 = 1954 model year
H = Detroit Truck Plant
27000 = serial number
116 = 116 inch wheel base
151 3600 = 151 certified net HP @ 3600 RPM
5DIR = 5 speed direct transmission. Make and model or other id will be cast into the case or maybe on a tag attached.
717-977 = two speed axle ratios
R = looks like color code for vermilion
25 = might be Richmond district code
Unsure on the rest. Sorry for the confusion.
Last edited by 85e150; Apr 22, 2022 at 02:59 PM. Reason: finally get it (mostly?) right
Old Apr 22, 2022 | 04:04 PM
gjinc's Avatar
gjinc
Thank You!
jcjc123
Apr 21, 2021 11:27 AM
1979FordSask
May 8, 2020 04:12 PM
Gary38532
Dec 3, 2017 08:24 PM
bigmike1024
Aug 13, 2012 03:27 AM
