No backup lights
Old Apr 29, 2022 | 07:22 AM
projectSHO89's Avatar
projectSHO89
Originally Posted by Edd505
BCM was the issue, Ford says they reprogrammed which leads to the new question. What would cause the BCM to forget what it was supposed to do, the truck pure stock?
It sounds like it didn't "forget" anything. It "remembered" that a severe fault was present and followed its programming to disable the FET driver circuitry. Once that happens a scan tool MUST be used to restore "normal" operation after the original fault is corrected as I previously noted.
Old Apr 29, 2022 | 07:12 PM
Edd505's Avatar
Edd505
Duplicate of following.
Old Apr 29, 2022 | 09:12 PM
Edd505's Avatar
Edd505
I still do some work on my Ford trucks, F150 & my F350, but I have to admit I worked for Ford/Lincoln/Mercury when electronic ignition was the new technology, how many here can rebuild a carburetor? .At the prices these days I have to do as much as I can, switched careers and technology left me behind in this field. should have stayed with mechanics my retirement would be better ...............
frankjhall
Nov 25, 2015 05:41 PM
skip hatfield
2004 - 2008 F150
Mar 17, 2010 02:02 AM
01redcrew
25
May 18, 2007 08:38 PM
dweddell
Electrical Systems/Wiring
Jul 9, 2003 06:31 AM
