Problems after injectors
Old Apr 14, 2022 | 08:55 PM
Somewhat_Trying20's Avatar
Somewhat_Trying20
Trailering
Should I pull the Hydra off and then try running it? I’ve read the 00 tune is stock and I’ve also heard it’s just the last tune the pcm remembers, if that’s the stick tune try that I assume? I don’t have an actual stick tune
Old Apr 14, 2022 | 08:56 PM
Somewhat_Trying20
Trailering
* Stock not stick
Old Apr 14, 2022 | 09:13 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
I have a not yet installed Hydra, I am driving on stock tune with old TS6. I cannot give you too much info but '00' aka double aught on the Hydra sticks in my mind as base tune on PCM.
Also, here is that o-rings I told you about earlier from the turbo to the Y plenum - https://www.dieselorings.com/1994-19...et-o-ring.html These compress with age and can leak boost.
https://www.ford-trucks.com/forums/1...l#post20367878 That is how I just drove into town. No IC, basically stock TP38, leaking driver manifold.
Old Apr 14, 2022 | 09:26 PM
Somewhat_Trying20
Trailering
For sure, just stopped at a gas station a long the interstate for the dog to get out. Still got three hours left on the trip so I’ll try the stock tune and let you know how it goes.
Old Apr 14, 2022 | 10:44 PM
96 OBS's Avatar
96 OBS
Stock tune should be a “like stock” tune. As in stock like behavior with the injectors you have. If that doesn’t help try taking the hydra out completely as Eric mentioned. He’s running stock injector tune on 205/30s so you should be fine
Old Apr 15, 2022 | 07:14 AM
FinnishStroker's Avatar
FinnishStroker
Originally Posted by Bitterroot Diesel
It's either the truck, injectors, tuning or combination.
Solid all around advice...
Old Apr 15, 2022 | 11:10 AM
Somewhat_Trying20
Trailering
Well putting it in stock didn’t really do much, cooked it down maybe between 50-100 degrees. Speedometer still shakes, straight rolling coal and now to even get it to 4th/OD I have to floor it but it’s way too hot to even let in stay in that gear.
Old Apr 18, 2022 | 01:57 PM
Somewhat_Trying20
Trailering
On my way back to Tennessee and decided to try just keeping OD off to see if that helps and it’s kept me under 1300 degrees pretty consistently. I’ve hit it or over it maybe a couple times but then the temp dropped back down. With the 00 stock hydra tune or my daily driver tune At 65 with cruise control set I’m sitting at about 1175-1250. Speedometer shake has decreased a little while doing. Haven’t noticed any real difference between using either tune while doing this.
SchaefferUSMC
Feb 9, 2018 10:15 AM
Jordanangel
Jan 25, 2018 09:46 PM
ToddMyers58
18
Jan 27, 2017 08:43 AM
owenstout
Oct 31, 2009 08:16 PM
blake 7.3L
18
Feb 6, 2009 10:29 AM
