Stock Radiator
Old Mar 27, 2022 | 09:41 AM
Oligny51's Avatar
Oligny51
Stock Radiator
Anyone using a stock radiator to cool engine other than original flathead. It seems everyone wants to change to aluminum but is it necessary? If I can change the inlets/outlets should it work just as well? I plan on running clutch fan from original engine which fits nicely inside original shroud. Does anyone know specs on the original rad? My truck is a ‘51 F1.
Old Mar 27, 2022 | 11:51 AM
tip49's Avatar
tip49
Original rad
When I first "restored" my F47 I had my rad core replaced. I am running a 5.0L engine and had a radiator shop build me a rad using the stock frame and new core from a 70's Chev. I paid $325 in 12 years sgo. Last Summer I shopped around to have my radiator repaired, quotes were $1000 for a 3 row, copper core. I reluctantly went with an Aluminum rad from Speedway.
Old Mar 27, 2022 | 12:34 PM
49willard's Avatar
49willard
If you have a good stock radiator I would use it. I easily cooled a 56 Buick nailhead V8 driving cross country in late June many years ago flat towing a Model A with good weight in the bed and it was hot coming cross country on I80. I had recored the radiator a year or so before the trip. The picture is loading up for the trip in Ca.
Old Mar 27, 2022 | 01:09 PM
moejr's Avatar
moejr
A radiator repair shop can change your inlet / outlet configuration, had mine changed to accommodate the 302 engine swap on my 49 F1.
Old Mar 27, 2022 | 01:28 PM
Oligny51's Avatar
Oligny51
That’s kinda what I figured. If my rad is good then why not. I’d love to use it if I can as to not waste good parts. 👍🏻
Old Mar 27, 2022 | 01:29 PM
Oligny51's Avatar
Oligny51
Yes I’d definitely have to do that with the different engine setup. 😊
Old Mar 27, 2022 | 01:34 PM
Oligny51's Avatar
Oligny51
Oh wow! That is very spendy. I’m thinking if I can flush it really good and have the inlet and outlet relocated/replaced I should be good. What is the reason they would normally need to be recored?
BTW…I’m in Beaumont, AB, what part of the province are you in? 🤔
Old Mar 27, 2022 | 01:45 PM
tip49's Avatar
tip49
Its only money...$$$$
Old Mar 27, 2022 | 01:47 PM
tip49's Avatar
tip49
my core was falling apart
West of Calgary...Cochrane
Old Mar 27, 2022 | 02:17 PM
Oligny51's Avatar
Oligny51
Haha. Isn’t that the name of the game if you’re into working on old iron! 😉
Old Mar 27, 2022 | 05:03 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Nothing wrong with the stock radiator.
A good thing to keep in mind when swapping radiators/engines, etc. You can end up with a weird mishmash of inlet/outlet sizes. You can get rubber reducer bushings in a range from 1 1/2" up to 3" (I think). I got mine through NAPA Auto but I'm pretty sure you can get them through several sources. If you Google "radiator hose bushings" you should come up with numerous options.
Old Mar 27, 2022 | 09:07 PM
Oligny51's Avatar
Oligny51
Good to know. Thanks Bobby. 👍🏻
Necromancer
Aug 23, 2015 07:12 AM
Gicknordon
Oct 3, 2012 05:48 PM
fontime
Jul 17, 2012 04:29 PM
51f1truck
Nov 2, 2008 10:20 AM
mh48
Jul 2, 2006 10:30 PM
