1992f150 reading low water temp
I know there is a tsb on the water gauge reading low for this truck. Trouble is alldata is the only place i can find the tsb and they expect cash!What is ford truck enthusiast all about?
I know there are others with the same problem.
Has anyone fixed theres yet?
Heres what I have done when researching the fixes for TSB 's . Ford has a data base called OASIS ...If you call your local Ford Dealer and talk with a service person that is knowledgable , give them the Tsb number , they will often tell you what the Tsb recommends as the repair . Ive had occasion to do this last week ...In fact I spent 20 mins on the phone , the tech I spoke with was very helpful and I thought went above the call of duty to help me out . He even gave me the revised part number of the Tsb I was asking about. Good luck with it .
Paul
Paul
Rough Idle/Hesitation/ Poor Heater Output
Article No.
93-24-8
11/24/93
^ HESITATION - ROUGH IDLE - ENGINE COOLANT DOES NOT REACH NORMAL OPERATING TEMPERATURE - MEDIUM TRUCKS WITH 7.0L ENGINES
^ HESITATION/STALL DURING ACCELERATION OR DECELERATION
^ IDLE - ROUGH - ENGINE COOLANT DOES NOT REACH NORMAL OPERATING TEMPERATURE
^ HEATER/DEFROSTER - POOR HEATER OUTPUT - THERMOSTAT STUCK OPEN
^ COOLING SYSTEM - NEW DIAGNOSTICS FOR ENGINES THAT DO NOT REACH NORMAL OPERATING TEMPERATURE
LIGHT TRUCK:
1984-94 BRONCO, ECONOLINE, F-150-350 SERIES, RANGER
1985-90 BRONCO II
1986-94 AEROSTAR
1988-94 F SUPER DUTY
1991-94 EXPLORER
This TSB article is being republished in its entirety to include 1994 model year vehicles.
ISSUE:
Engine performance concerns such as hesitation or stall, rough idle, and/or poor fuel economy may be caused by the thermostat stuck in an open position or opening at a temperature lower than specified.
ACTION:
Use the following "Cooling System Diagnosis" procedure to diagnose a cooling system that may not be reaching normal operating temperature. Follow the "Thermostat Diagnosis" procedure to determine if the thermostat may be at fault. Check the thermostat without removing it from the vehicle by using Rotunda Service Coolant Temperature Monitor Harness 007-00064.
A new cooling system diagnosis procedure has been developed for engines that do not reach normal operating temperature. A new thermostat diagnosis procedure also has been developed, using a new service coolant temperature monitor harness.
NOTE:
THIS PROCEDURE WILL DIAGNOSE ONLY COOLING SYSTEMS THAT MAY NOT BE REACHING NORMAL OPERATING TEMPERATURE. IT WILL NOT DIAGNOSE A THERMOSTAT THAT CAUSES AN ENGINE OVERHEAT CONDITION.
THERMOSTAT DIAGNOSIS
NOTE:
DISCONNECTING THE POWERTRAIN CONTROL MODULE (PCM) TO ATTACH A BREAKOUT BOX OR AN EEC IV MONITOR WILL ERASE THE ADAPTIVE LEARNING FROM MEMORY AND MAY "HIDE" A DRIVE CONCERN TEMPORARILY UNTIL THE ADAPTIVE LEARNING IS RE-LEARNED.
NOTE:
THIS PROCEDURE IS MOST ACCURATE IF PERFORMED INDOORS AT LESS THAN 100~F (38~C) AMBIENT TEMPERATURE. THIS TEST MAY BE PERFORMED WITH OR WITHOUT THE HOOD OPEN AND WITH THE ENGINE WARM OR COLD.
CAUTION:
ALWAYS VENT THE EXHAUST TO THE OUTSIDE WHEN PERFORMING THIS TEST.
1. Check the coolant level in the radiator and coolant recovery reservoir.
2. With the key in the "off" position, proceed as follows:
a. Remove the engine coolant temperature (ECT) sensor harness connector.
b. Attach Rotunda Service Coolant Temperature Monitor Harness 007-00064 as a jumper between the PCM and the ECT.
c. Attach Rotunda 73 Digital Multimeter 105-00051 or equivalent to the thermostat monitor harness. Voltage values (0-5vdc) may now be monitored while the sensor retains its connection to the wiring harness.
NOTE:
A ROTUNDA NEW GENERATION STAR TESTER (NGS) 007-00500 OR THE ROTUNDA SERVICE BAY DIAGNOSTIC SYSTEM (SBDS) 001-00001 MAY BE USED TO MONITOR THE ECT ON VEHICLES EQUIPPED WITH DATA COMMUNICATIONS LINK (DCL). THE SBDS SEQUENCE TO USE FOR THE SCREEN IS "TOOLBOX - ELECTRONIC ENGINE CONTROL AND DCL - ITEM".
3. Vehicles equipped with electric engine cooling fan(s) must have a fan running during this test (high or low speed may be used). Two methods may be used to turn the fan(s) on:
a. Disconnect the A/C compressor clutch power supply and turn the climate control to A/C "ON". Or
b. Disconnect the power supply to the cooling fan and supply 12 volts direct to the fan connector from the battery.
NOTE:
A GROUND MAY BE REQUIRED FOR SOME APPLICATIONS.
4. Place transmission in "park" or "neutral".
NOTE:
RUNNING THIS TEST WITH THE VEHICLE IN GEAR OR WITH THE A/C COMPRESSOR CLUTCH ENGAGED (RUNNING) WILL CAUSE IMPROPER DIAGNOSIS
5. Start the engine and allow to idle throughout this test:
a. Allow engine to run for 2 minutes, then record ECT voltage.
b. From now on, record ECT voltage every 60 seconds.
c. When the ECT voltage trend changes direction or changes only slightly (0.03 volts or less) from the previous reading, record this as the thermostat opening voltage.
d. Use the "Voltage and Corresponding Temperature Chart" shown to obtain actual coolant temperatures.
6. If the opening voltage is GREATER than 0.75 volts (less than 18~ F/ 82~ C), or 0.85 volts (170~ F/ 77~ C) for 2.3L HSC engine only, replace the thermostat. Refer to the dealer Master Parts Catalog for correct thermostat usage.
7. If the thermostat opening voltage is LESS than 0.75 volts (greater than 180~ F/ 82~ C), or 0.85 volts (170~ F/ 77~ C) for 2.3L HSC engine only, the thermostat is good and should NOT be replaced. The "Cooling System Diagnosis Chart" should be referenced for further instructions.
NOTE:
The 10~ F opening temperature difference for the 2.3L HSC engine is due to the ECT sensor location.
OTHER APPLICABLE ARTICLES: NONE
SUPERSEDES: 93-14-4
WARRANTY STATUS: INFORMATION ONLY
OASIS CODES:
208000, 208100, 402000, 608000, 608400, 609000, 609400, 611000, 611500, 622000, 690000
Copyright © 2000 ALLDATA LLC. Version 2.2
Article No.
93-24-8
11/24/93
LIGHT TRUCK:
1985-90 BRONCO II
1986-94 AEROSTAR
1991-94 EXPLORER
ISSUE:
ACTION:
NOTE:
NOTE:
NOTE:
CAUTION:
NOTE:
NOTE:
NOTE:
NOTE:
SUPERSEDES: 93-14-4
OASIS CODES:
StealthWyvern
05-22-2007 03:17 PM
Mr.Novice
1997-2006 Expedition & Navigator
09-26-2006 10:08 AM
