Intermitent indicators and dash lights
Old Feb 11, 2022 | 05:09 AM
JonnyUK's Avatar
JonnyUK
New here so hey all from the UK!
I've had my 71 F100 for 2 weeks now, whilst I love it I'm starting to find it's querks. I'm a total newbie when it comes to anything Mechanical or Electrical wanting to learn!
My headlights work (modern Halo LED's) and so do my brake lights, interior light, cargo light. However my indicator lights sometimes work, and sometimes flick off after 1 flash. When they arnt flashing on the dash they also don't flash on the front or rear lights. The same pretty much goes for the light cluster at night it flickers vividly and then dissapears altogether, so night time driving is sketchy inside.
I've been reading around and wondering if it could be a bad grounding? I spotted a loose ground earlier near the front RH headlight, but not sure if that would be causing it as it is technically touching something, or a loose connection in the dash?
Any help would really be appreciate, thanks!
Old Feb 11, 2022 | 12:26 PM
RTT's Avatar
RTT
I would turn light switch to where only the dash lights come on, ( I think you can do that ??? ) Try turning switch to the left. Anyway turn on dash lights & take your hand & move some of the wires under the dash/ behind the instrument panel and see if the dash lights flicker !!!
Maybe tap slightly on the front of the plastic instrument panel. You may have a lose wire. If it flickers then take out the panel and check for a loose connection or bare spot in wiring insulation............
Old Feb 11, 2022 | 04:46 PM
FoPar1972's Avatar
FoPar1972
RTT
I second that... I had similar issues and found it to be the head light switch. Replaced it with a new one from DC (Dennis Carpenter) and fixed the issue. but make sure to check your grounds as rusty (or painted connections if restored) will cause a lot of electrical headaches.
Good luck
Old Feb 12, 2022 | 01:26 PM
JonnyUK's Avatar
JonnyUK
Thank you both! Oddly yesterday morning I had no indicators at all, then when driving back from work they worked perfectly for the 30 minute drive home.
I'll try wiggling the wired and tapping on the cluster. If not my thoughts are a loose connection. I'm not sure the grounding could be the issue as it would surely effect the front and rear light full stop.
Old Feb 15, 2022 | 09:09 PM
JEFFFAFA's Avatar
JEFFFAFA
Welcome to FTE.
I think you may have two separate problems that the PO (previous owner) didn't fix.
But first look up behind the dash. See if the wiring looks like a hacked up mess.
The cluster lights could be the headlamp switch, printed circuit board on the back of the cluster, or the ground wire that should be screwed to the bottom of the metal dash. I believe 1971 had this ground wire.
The indicator lights could also be the printed circuit board, turn signal switch, or the flasher unit. Some call this a flasher can.
Old Feb 16, 2022 | 04:24 AM
JonnyUK's Avatar
JonnyUK
Originally Posted by JEFFFAFA
Welcome to FTE.
Thank you for this! I'll have a good luck when I get chance to take off the dash. It must be a bad or loose connection somewhere, which would explain why sometimes they works and sometimes they don't. The wiring has a lot of zip ties underneath but looks OK. Apart from the fact someone spliced in an aftermarket Cruise Control at some point, which needs cutting out.
LARIAT 85
23
Oct 23, 2019 12:21 PM
PapaGeek
General Automotive Discussion
Jul 2, 2016 06:14 AM
bluesnake2006
Jun 21, 2015 01:34 PM
bamboo321
Feb 1, 2013 06:20 PM
ASoCalCowBoy
Nov 12, 2006 10:13 PM
