Console vaults
Old Jan 24, 2022 | 12:57 PM
cpobst's Avatar
cpobst
Originally Posted by ibeb
Contact Nick at Apollo Optics via the link above for the E&G vault. He posted on the Tremor forum that he was still able to get them/had them.
I did exactly this and got one on order. He said they are still being manufactured and supported.
Old May 18, 2022 | 07:15 PM
cpobst's Avatar
cpobst
So I finally got this installed 4 months later. It's really nice, install was easy. The factory change tray fits a bit tighter than I'd like so I'll probably make some reliefs in it to loosen it up. Other than that it's high quality and fits well.
Old May 19, 2022 | 09:48 AM
rednex's Avatar
rednex
I've had console safes in my trucks (aftermarket) since they were first made and I've always been happy with them. So on the 2022, I got the OEM one from the factory. It wasn't long after I placed my order that I found the below safes from Lock'er Down. In comparison, I kind of wish I would have not ordered the OEM one due to the fact that the Lock'er Down appears to have a much wider door opening and possibly a better locking mechanism. While this doesn't resolve your change tray issue, I figured it might be worth a look. Looks like there may be a swap out in my future.
https://www.lockerdown.com/i-182-exx...ref=category:3
Old May 19, 2022 | 10:00 AM
cpobst's Avatar
cpobst
That one is similar style to OEM as it doesn't allow the tray to be used. I wanted the tray and to have the unlocked portion for quick access things. A little filing on my tray will allow it to fit better. I was surprised the OEM didn't allow the use of the change tray but I understand they don't actually manufacturer them.
Old May 19, 2022 | 10:38 AM
rednex's Avatar
rednex
Yeah, they are just rebranded Console Vaults. The thing that I like about the Lock'er Down is the much bigger opening. I put my Fusion Trailer cam screen in the vault when I'm not using it and it takes some wiggling to get it in the Console Vault opening due to the smaller size. But absolutely agree, this doesn't solve your tray issue. I don't honestly know if the below will fit in the console vault (doubt it will), but I have it on order and plan to try it out. If it doesn't work, I may be willing to just sent it to you.
Amazon Amazon
Old May 19, 2022 | 10:43 AM
cpobst's Avatar
cpobst
https://www.amazon.com/dp/B07PCWFQMJ...v_ov_lig_dp_it
That looks interesting for sure! Make sure you update us when you try it out.
Old May 19, 2022 | 09:13 PM
Lux194's Avatar
Lux194
I have the E&G in my ‘22 F250 and the tray wouldn’t fit. The tray from my ‘18 F150 did fit though, so I swapped them before trading in the F150. You might try to find a tray from an F150. I did inquire with Apollo Optics about the tray issue and they reached out to the E&G people. They said Ford uses a couple of different manufacturers for the tray, so some have fit and others have not. They plan on making an adjustment to their manufacturing to fix the issue.
Old May 19, 2022 | 09:15 PM
cpobst's Avatar
cpobst
Good to know!! Thanks for posting this👍🏻
Old May 20, 2022 | 02:39 AM
Squanto's Avatar
Squanto
Is the lid spring loaded to stay open? I hate when you have something like that and the lid is trying to shut on you when you're trying to dig for something.
Old May 20, 2022 | 05:41 AM
cpobst's Avatar
cpobst
It stays in whatever position you open it to without falling 👍🏻
Old May 29, 2022 | 12:53 PM
alinosa's Avatar
alinosa
I had one of these in my F-150 and tried to get it to work with the console vault in my F-250. No dice. Because of the way it mounts, it needs access to the rails that the hanging file tabs fit into. Ended up giving it to a co worker. Shame too because it was nice to have loose bits organized vertically. You do need enough "approach angle" to get to the lower bins though. Going through the small opening on the console vault would have bene a pain.
Old May 29, 2022 | 09:16 PM
scottz99's Avatar
scottz99
Veteran: Navy
This is the one I have. Tuffy Console Safe Yes, the OEM tray will fit (on top of the safe lid) and it can be ordered with key or combo. I bought model 317-01 for my '19 F-450; fits perfect in my '22. The combo lock option is not apparent on their website, but pretty sure they still have it. When I bought it they swapped the key lock for a combo lock for minimum charge: $10 I think.
Old May 29, 2022 | 09:58 PM
  #28
Squanto's Avatar
Squanto
Better price than others.
Old May 30, 2022 | 08:03 AM
  #29
Squanto's Avatar
Squanto
Originally Posted by dburby08
I think I like this one the best of what I've seen so far. I dont need the entire console locable. Just enough for wallet, extra cash a small bag of priceless jewels to impress my friends. Maybe a glock. I'd like to have room for some snacks and not valuable papers etc.
Old Jun 6, 2022 | 04:10 PM
  #30
PeaceNique's Avatar
PeaceNique
Originally Posted by Joe T
No there is no tray with the Ford one. At least not as of 2019
It's not in the '22 either.
