Hello, I have a 2002 f250 V10(brand new long block), 6" lift running 37s, regeared 5.13 and rear end locked, not afraid to cut some sheet metal, but enough about me.
I have a set of 38.5x11x16.5 boggers that I would like to run, and if you're aware, finding 16.5 wheels with a 8x170 bolt pattern is tough. I'm looking at ordering a custom set from diamond racing wheels as I've had good luck with them on the half ton side (5x5.5) but it's been about a decade since I last ordered and I'm totally garbage with figuring out the math on offset and backspace. I would like them to stick out maybe 3" from stock but not much more, any help would be awesome.
