Locking out gears while towing?
Old Jan 19, 2022 | 11:50 AM
Fish2Win's Avatar
Fish2Win
Hello,
This is my first post here on the forum. I have owned 3 trucks in my lifetime ('78 Ford 150, 2000 F250 7.3L diesel, and my current 2014 F150 5.0L). I just ordered a new 2022 F250 with the 6.7 diesel. I have always locked out 6th gear when towing my boat with the F150 and it makes a big difference. My 2000 diesel had an "overdrive" button on the shifter that I would push when towing. My question is, with this new 10 speed transmission, do any of you lock out the gears while towing? I read other posts that some people lock out 8, 9, and 10 while towing. I am not familiar with the new 10 speed transmission, so I don't know if it is necessary with the power of the diesel. I tow a boat that is usually less than 3,500 pounds total weight. I know the truck might be overkill for what I do, but I do travel long distances with it. Thanks for any and all responses.
Old Jan 19, 2022 | 11:52 AM
archer75's Avatar
archer75
I don't. I put it in tow haul mode and let it do its thing.
Old Jan 19, 2022 | 11:57 AM
OverheadCram's Avatar
OverheadCram
3500lbs in tow with the 6.7L, personally id just drive it like you're not even towing anything. I can put 7-8k behind my 6.7L before I have to operate it differently from unloaded.
Old Jan 19, 2022 | 12:10 PM
NeverboughtanFseries's Avatar
My 350 doesn't recognize the weight of my bass boat in terms of fuel mileage, that I can tell anyway. I don't lock out any gears unless I'm going uphill, I won't allow overdrive to tow weight uphill.
Old Jan 19, 2022 | 12:13 PM
BSHORT's Avatar
BSHORT
Top Answer: 5
I lock out 10, because any variation in terrain will kick it to 9 anyway. It holds 9 very well and runs about 2k at 65. 7.3/4.30
Old Jan 19, 2022 | 12:31 PM
2021F350's Avatar
2021F350
Putting it into TH mode effectively cuts out 9th and 10th gears on my 6.2 F350 unless going over 60MPH. then it goes into 9th and at 65MPH into 10th...
Old Jan 19, 2022 | 12:36 PM
Beast2.0's Avatar
Beast2.0
Originally Posted by Fish2Win
Hello,
Not sure if you know this but here goes..... To lock out gears, you use the up/down toggle on the shifter. You can turn gear display off using that as well.
Old Jan 19, 2022 | 12:39 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Hello,
With that light of a load, you will never need to worry about limiting any upshift in the trans, it will tow 3500 pounds up the steepest grade at highway speed without ever breaking a sweat. Of course, that is assuming you won't be adding some really tall tires or something like that.
When I tow heavy in rolling hills, or some situation where I want more instantaneous pulling power when off of cruise, I may limit the trans to 9th or even 8th, to keep the response to throttle inputs quicker, without having to wait for the trans to downshift itself. This is also only when travelling at less than 70 mph.
But, as I stated, with only towing 3500 pound boat/trailer, you will never need to worry about it.
Old Jan 19, 2022 | 12:44 PM
Fish2Win's Avatar
Fish2Win
Yes, sir, I know about the plus and minus button. I appreciate the heads up though. Someone told me about it when towing with the 2014 F150, and it made all the difference. It's been 8 years since I've owned a diesel, and miss my 7.3L dearly!! Can't wait for the new one!! Thanks again!
Old Jan 19, 2022 | 12:51 PM
shawnee1's Avatar
shawnee1
OP, you need a bigger boat
Old Jan 19, 2022 | 12:54 PM
Fish2Win's Avatar
Fish2Win
LOL! Good one!!
Old Jan 19, 2022 | 12:55 PM
Rob89's Avatar
Rob89
The 6.7 is an absolute beast and I’d be surprised if it acted any differently towing 3500 pounds than it does unloaded.
Old Jan 19, 2022 | 01:04 PM
MKrenn's Avatar
MKrenn
I use tow/haul and select "M" on the gear shift. That way I can choose when the truck will shift up and down. I found this out through experience. with what your planning to pull and what you have on order, you could just put it in drive and let it do it's thing. However, when you have cruise set pulling and descend a hill, the tranny wants to downshift to compensate for the additional speed. I know on my 7.3 gaser, it wants to scream with RPMs to get it slowed down. That's the reason I use M mode............
Old Jan 19, 2022 | 01:08 PM
2021F350's Avatar
2021F350
I agree with the screaming engine, dropping a few gears is great, but, really? What's with it dropping into 3rd doing 55MPH.?
Old Jan 19, 2022 | 01:16 PM
MKrenn's Avatar
MKrenn
Not sure what your question is?
