cruise control not working
#107
There is a switch at the master cylinder.
Change the switch at the master cylinder with this kit:
https://www.ebay.com/itm/OEM-Genuine...NZAkcW&vxp=mtr
#108
I remember seeing it . I just don't know if I preformed it correctly. I did replace the brake like switch tonight to no avail. That didn't fix it . I think I need to say what I know what else that doesn't work. This " might " , help others help me .
Driver side window doesn't work
remote mirrors ( both ) don't work
cruise doesn't work
auxiliary brake box doesn't work
Oh ! And the overdrive off switch doesn't work.
cruise doesn't work
I you haven't already done so, check and clean all the ground connections. Where the battery cables connect to the block first, then the grounds on the body in the engine compartment and then the ones in the interior. I believe there is one under the drivers side kick panel.
#109
#112
2000 excursion v10 cruise not working
Hello guys and gals. Im at my whits end with this cruise. I got the truck and it had a bad clockspring so i replaced that and now my air bag light is out and the buttons are working. I run the static test and everything passes and the servo motor runs but when I take it out on the road the cruise does nothing, no lights or anything. Any ideas?
#113
#114
#116
Ok I understand that but I don’t know how to find if I have a valid vss signal or if it’s compromised. I have a new sender in the rearend. How do I test this? It sounds like it’s the most likely issue being that everything else seems to be ok. Thanks for you time.
