Taillight shenanigans
Old Jan 6, 2022 | 02:07 AM
Marsh90250's Avatar
Marsh90250
Hey all, if you’re from the Midwest it’s getting pretty cold up here, about 10 degrees on average and some funky things have been happening with my taillights. Sometime my reverse lights stay on when I’m driving, sometimes the brake lights don’t come on, the rear turn signals when turning right flash both the rears, and the running lights for the taillights don’t come on. The wiring job by the PO was messed up so I pulled and repaired the taillights wiring harness and everything worked great again. But man have some weird things been happening since it got this cold around here. I would explain more but there doesn’t seem to be any rhyme or reason to it. Also when the turn signal is on, the clicker or whatever it’s called clicks super slow. Seems like the weather is making things pretty tough on this truck -electrically, thankfully nowhere else but still annoying and probably not too safe on the roads.anyone else experience anything like this? Super frustrating and confusing.
Old Jan 6, 2022 | 02:21 AM
AuroraGirl's Avatar
AuroraGirl
I would say pull the connectors apart again and use bulb grease in the sockets after cleaning and drying fully with electrical spray and then dielectric grease in the frame ones. check ground path from chassis to frame and both of those to batttery
Old Jan 6, 2022 | 06:55 AM
rla2005's Avatar
rla2005
The rear tail/stop/park lamps are grounded at G100 located on the driver side of the radiator support. There are a few splices along the way. Only the chassis cab F350 uses the frame as ground for these circuits.
Old Jan 6, 2022 | 04:11 PM
Marsh90250's Avatar
Marsh90250
I’ll cleans up that area, pretty sure I was working on or around that area a few days ago. Funny how that happens
Old Jan 6, 2022 | 09:15 PM
Marsh90250's Avatar
Marsh90250
Cleaned up the grounds you mentioned still having an issue, I figured it out - the problem. When my lights are off the turn rear turn signals “work” but both are going off at the same time like the hazards would. When I turn my headlights on the brake running lights don’t come on. Checked the bulbs, they’re fine. When I turn my turn signals on with the headlights on the flasher clicks real slow and the rear lights light up really dim. Almost like a loss of voltage. New alternator and fresh battery so that can’t be it. Any ideas? Maybe the flasher is going bad? Pretty cold out here parked my truck in the garage so it’ll warm up and hopefully I’ll be able to rule out the cold weather doing this.
Edit: replaced the flasher, issue proceeds. I believe it’s some sort of impedance. If the headlights are taking too much amperage possible a bad wiring harness or ground or somthing in the rear harness for the taillights.
Old Jan 7, 2022 | 06:05 AM
torq'ta 5 8's Avatar
torq'ta 5 8
what year truck, I forget what year it started, but Ford() was nice and put the turn flasher, and the hazard flasher, on top of one another, the one you see, where fuse panel under steering wheel, cover off, there is another flasher behind/or stacked on the one you see.
Old Jan 7, 2022 | 06:52 AM
rla2005's Avatar
rla2005
The funky rear tail/stop/park lamps could be a bad multi-function switch. I have seen quite a few grown green corrosion. That stuff is conductive which can cause weird operation. There physical connection between the headlamps and tail lamps are the headlamps switch and the battery and grounds. One headlamp is grounded at G100, the other at G101 (near the battery). I believe one of the front park/turn lamps also grounds there. An open ground connection for one of these high current devices can cause issues. One common symptom is the engine dies when you turn on the headlamps. A bad or melted headlamp switch can also be the culprit here.
Are you sure the alternator is charging the battery? It may be new but that does not mean it is good. If the green/red wire does not have voltage with the key in the Run or Start position the alternator will not turn on as well.
Old Jan 7, 2022 | 02:26 PM
Marsh90250's Avatar
Marsh90250
I’ll have to look into the multi function switch. Figured out that when I’m driving and the trucks under load, the taillights work properly. So it’s either an impedance of sorts, most likely at the connector to the rear harness since only the rear taillights seem to be affected and not the front blinkers. I did that test, alternator is good, battery’s good, those grounds are good. Truck does not shut off when the headlights turn on. I believe that rules just about everything out besides the multifunction switch you mentioned and the connector for the rear harness.
Old Jan 7, 2022 | 02:27 PM
Marsh90250's Avatar
Marsh90250
Originally Posted by torq'ta 5 8
what year truck, I forget what year it started, but Ford( was nice and put the turn flasher, and the hazard flasher, on top of one another, the one you see, where fuse panel under steering wheel, cover off, there is another flasher behind/or stacked on the one you see.
my truck is a 1990 F-250 351W 4x4 5spd ZF trans.
Old Jan 7, 2022 | 03:06 PM
Marsh90250's Avatar
Marsh90250
Alright I did figure it out, normally i’m pretty decent at wiring but I guess the crimp job I did on the rear harness wasn’t good enough, i wiggle the harness and my tail lights come on and off, thanks for the help everyone. I got it from here
Old Jan 7, 2022 | 03:18 PM
rla2005's Avatar
rla2005
Another reason to solder then use shrink wrap.
Old Jan 7, 2022 | 03:27 PM
Marsh90250's Avatar
Marsh90250
Just took another look under the truck, It was the ground wire which I didn’t crimp, hats off to the PO haha for his lame crimp job. I agree solder is better but crimping can be more than adequate in most situations with the proper tools ie a crimper
Old Jan 7, 2022 | 03:49 PM
rla2005's Avatar
rla2005
Not here in the rust belt. 3-5 years tops before this issue would rear it's ugly head again.
Glad you found it.
Old Jan 7, 2022 | 09:33 PM
Marsh90250's Avatar
Marsh90250
Glad you found it.
thank you sir, I’m in the rust belt too, I found a decent crimp kit which comes with heat shrink on it already, not those crappy plastic ones you find at the store… I believe it’s called wirefy found them on Amazon, haven’t had a failure yet. Time will tell
Lin zimmerman
All Things Towing
Dec 2, 2019 09:30 PM
cool mac
Apr 27, 2016 02:10 PM
BTFordGuy302
53
Nov 29, 2015 04:04 PM
KCFordFANatic
1997 - 2003 F150
Jul 18, 2015 05:13 PM
amsnss
Mar 18, 2014 08:09 PM
