Crank no start
Old Dec 12, 2021 | 10:58 AM
Tnero998's Avatar
Tnero998
Crank no start
Got a 2000 that decided it does not want to start. Got a code for idm and pcm not communicating. Tried a new idm still won’t start also tried CPS. I’m not very mechanically inclined but not incompetent either. Tachometer moves when trying to start and I don’t get any smoke from the exhaust. Oil level is good and I’m getting fuel to the fuel bowl. It cranks and cranks but won’t fire not even with starting fluid. I’m at a loss with it and was looking for recommendations
Old Dec 12, 2021 | 11:00 AM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Check fuse for PCM. It probably blew because the fuel bowel heater shorted to ground. Disconnect heater and replace fuse. Starting fluid is BAD.
Old Dec 12, 2021 | 11:31 AM
Tnero998's Avatar
Tnero998
Codes
I now had code p1280 p1670
Old Dec 12, 2021 | 11:38 AM
Wes444's Avatar
Wes444
A member recently acquired a no start truck that had a few empty cans of starter fluid in the bed
Starter fluid and glow plugs = bad
That said, it's your truck and we literally can't stop you from using it
Try starting it with your ICP sensor unplugged. It's the one on the driver's side head
Old Dec 12, 2021 | 11:44 AM
Tnero998's Avatar
Tnero998
I should’ve also stated that I tried it unplugged as well, my bad.
Old Dec 12, 2021 | 11:49 AM
Wes444's Avatar
Wes444
Pull and replace fuse #30 (also a 30amp fuse) under the dash. Even if it looks good, contacts could be worn or light corrosion.
Do you have the wait to start light?
Have you swapped the IDM power relay under hood for a different relay from something non critical like the AC blower?
Old Dec 13, 2021 | 11:15 AM
Tnero998's Avatar
Tnero998
after I swapped the fuse out it sounded like it wanted to start more and also blew out more smoke. It definitely wants to start just not sure what else is stopping it
Old Dec 13, 2021 | 01:01 PM
DND58's Avatar
DND58
Plug it in for a couple hours, then try starting
Old Dec 14, 2021 | 10:56 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@Tnero998 , hopefully you got the old engine fired up already, but in case you haven't.
Below are a couple of "no start flow charts" that may aid you in getting it fired up again. Along with the advice from the fellas above of course. Keep us updated!
dmcgann
15
Jan 2, 2015 01:36 PM
mjtpolice76
Apr 5, 2014 07:54 PM
casey smith
19
Apr 13, 2013 01:00 PM
Lady1989
13
Oct 5, 2011 07:33 PM
lakewood
Jun 28, 2011 04:28 PM
