Bypass Filtration System on your PSD
Frantz....
I have installed 3 Frantz filters on my 99.5 PSD. On the Engine, Trans, and fuel line.. Installation was easy.. Maintenance is simple.. filters are economical.. I am 110 % Happy! with it.. Wish I had used Frantz 20 years ago.. e-mail me if you have any questions.. I have installation photos soon to be posted on the web.. A filter for the Coolant is in the works too ..
From a new PSD owner.<br>
What is the purpose of these filters, to extend the time between oil changes or???<p>
I do mostly highway driving, about 2500 miles a month, would it be beneficial to me or are they intended mainly for hard driving and/or dirty enviroments?<br>
Could someone post a link to their favorites so that I may learn more?<br>
Thanks,<p>
Steve.....
Thanks,<p>
Steve.....
I am using a Gulf Coast Filter By-Pass-Oil-Filter. Much of DOD has started using these systems as a way to cut maintenance costs and it has worked, our Diesel fleet at Davis-Monthan AFB has seen a 50 % reduction in engine wear related maintenance costs in the last 2 years. I tracked down the company and bought a system for my PSD. It was easy to install and doesn't take up much space on the frame. I now have 12k on Mobile Delvac 1 and the oil analysis keeps coming back as "Like New" the filters are pulling out most of the soot and all of the particles.
According to GCF I shouldn't have to change it ever again. I'm not sure that I believe that just yet, but my oil is still transparent. We do have several USAF fleet vehicles with well over 90K-100K miles on the same oil at our base.
I have only had to change the GFC filter once so far. The recommendation is to change the GCF filter ($17.00/ try to buy them in bulk to save on shipping) every 10,000 and the factory every 25,000. The GCF filter will bring your total oil capacity up to 16Qts. You do wind up replacing about 2 1/4 Qts each time you change the GCF filter. One point to note, buy two brass ball-valves and put one on each filter hose. There was no problems on my PSD but a couple fleet vehicles had the GCF filter mounted lower than the oil pan. This caused the oil pan to siphon out when they changed the filter.
One other idea: get a Fumoto Oil Drain Valve , it will make taking sample a million times easier.
Thanks,<p>
Steve.....
Thanks,<p>
Steve.....
http://gulliver.trb.org/publications...ACulpepper.pdf
http://www.garynorth.com/y2k/detail_.cfm/5359
www.wefilterit.com
www.bypassfilter.com
USAF CCM,
Former Boomer...Breakaway, Breakaway, Breakaway!
We may have crossed paths somewhere. I'm a High Band Operator on the EC-130H Compas Call. Been here since 96' .
My additional job for our squadron was as the VCNCO. The fleet MX guys introduced me to these filters. Told me I should get one even for the gasser I drove at the time. I should of listened !
I have the filtration solutions fs-2500. I no longer use it and it is up for sale along with 12 filters.
I bought the system to extend oil changes, extend engine life and save money in this order. What i got was different, yes it extended oil changes but i dought that engine life is being extended and i didn't save any money.
I sampled the oil prior to installing the unit and 6 time after and the best report was without the system! 5 reports said okay for continued use and 1 said abnormal, change oil. The claim that it will extend engine life in my book is bull! How can engine life be extended when the contaminates that is floating in the oil is elevated? As for saving money from oil changes, I have spent more money now then if i continued changing oil at 3000 mi. and i will never recovered from the initial cost.
To each his own but i would say save your money and change oil @3000 mi. is the best protection.
e-mail me if you would like me to fax copies of my reports or buy this filter system.
gseeders
gseeders
