460 WON'T RUN
Old Nov 6, 2021 | 09:03 AM
448thaaabn's Avatar
448thaaabn
460 WON'T RUN
My 96 F250 4x4, 7.5 V8, C6 auto tranny, won't start or run. Thought it was my PCM, but still won't run. Has spark, fuel pressure is 38, timing is good. New throttle pos sensor, intake air temp sensor, IA Valve, MAP sensor.
Any Ideas out there? I'm the original owner.
Old Nov 6, 2021 | 10:36 AM
jas88's Avatar
jas88
Try starting it on starting fluid to see if problem is fuel or spark.
Old Nov 6, 2021 | 11:43 AM
448thaaabn's Avatar
448thaaabn
Did that yesterday. I checked for spark, but it looked yellow, instead of blue. Just pulled the coil out, and the steel field around the coil is broken loose. Just put that coil in on March 15th of this year.
Cheap aftermarket Chinese junk! I will have the new coil at 1:30 this afternoon. Keep my fingers crossed. Thanks for the info though.
Old Nov 6, 2021 | 05:50 PM
torq'ta 5 8's Avatar
torq'ta 5 8
O'Reilly's, $10 bux more than china, motorcraft.
Campbell 56
15
May 21, 2016 11:26 AM
Mwvwaw
Jan 8, 2016 03:05 PM
shawbran
Oct 12, 2013 04:42 PM
rickye
1978 - 1996 Big Bronco
Jul 27, 2004 10:24 AM
classic79
Dec 10, 2001 06:52 PM
