Coil pack issues
Old Nov 22, 2021 | 11:17 AM
pdqford's Avatar
pdqford
Does that year have a fuel filter?
Old Nov 22, 2021 | 07:16 PM
RLXXI's Avatar
RLXXI
No not really, there's a strainer on the fuel pump and that's it. Can only be replaced as an assembly.
Old Nov 30, 2021 | 08:18 PM
Bronc1's Avatar
Bronc1
I'm going to throw a new set of plugs at it this weekend even though the current plugs only have 20K on them, maybe one or more are bad. After that I don't know.
Old Nov 30, 2021 | 08:33 PM
RLXXI's Avatar
RLXXI
Originally Posted by Bronc1
Update. I installed new coil packs and the problem is worse. At slow acceleration the truck hesitates at other times under a load when stopped the engine speeds up. While sometimes stopped and shifting from forward to reverse the engine drops to around 350 RPM than dies. I used Excel coil packs.
Fix that problem while your at it.
Old Dec 2, 2021 | 08:01 PM
Bronc1's Avatar
Bronc1
The truck ran worse when I picked it up from the dealer after the fuel pump replacement then it did when I dropped it off, again after the seals were replaced, and again after I replaced the coil packs. The common element is that the battery cable was disconnected for an extended length of time during each repair. Over the next few days after each repair the engine performance improved. Currently, for example, the truck doesn't hesitated during light acceleration or want to die, my only problems now are low idle RPM and a vibration that no one can explain.
Old Dec 19, 2021 | 09:27 PM
Bronc1's Avatar
Bronc1
I replaced the injectors this weekend and found oil in the electrical connection on four of the injectors. After replacing the injectors I drove the truck and the engine had more power under hard acceleration but no change at low acceleration. I than disconnected the battery and reconnected to clear any codes now the truck doesn't want to idle and surges.
Old Dec 20, 2021 | 07:50 AM
BassFantasizer's Avatar
BassFantasizer
Can you elaborate a bit? I take that to mean that there's an external oil leak that somehow made its way into those connectors, which seems unlikely.
Old Dec 20, 2021 | 09:30 PM
Bronc1's Avatar
Bronc1
Bass,
I pulled the white connector away from the injector and saw a shinning substance in the injector housing than looked at the plug and saw it was covered in oil. I used electrical contact cleaner to clean up the plugs before reinstalling. This occurred on four of the injectors three on one side one on the other the rest were clean. I still have the old injectors so I'll post a pic soon. None of the injectors were cracked so the oil had to come up from the engine.
marcrex
2004 - 2008 F150
Mar 27, 2019 11:08 PM
idealtrucks
Mar 19, 2019 08:40 AM
gabriell12123
Sep 5, 2018 09:27 AM
hannibal0268
Jan 6, 2014 01:45 PM
Jaguar2u
Escape & Escape Hybrid
Sep 15, 2012 08:23 PM
