When I switch to the front fuel tank the engine dies and the fuel gauge moves quickly past the full mark. This truck has been sitting and only has 7000 miles on it. The rear tank works fine. Thanks, Rob.
Sounds as if the connector on the tank has fallen off or needs to be cleaned, You should be able to take it off without pulling the bed or dropping the tank.
