Tools and equipment to keep our 6.0s running
I was carefully scraping away from coolant holes. That was not the best way. Some said to use shaving cream.
The following 5 users liked this post by bismic:
The following 2 users liked this post by SmackDaddy:
The following users liked this post:
Sometimes it happens that you cannot be sure that an injector is the cause of the issue. Here in Germany there is no company that can test HEUI injectors. I am trying to build a setup where I can at least see if an injector on the oil side has a leak. Oil leaks are not always easy to find.
Dang, amazing work. I thought I was ingenious for using a long 1/2" extension with a deep socket on the end to slip over the ratchet handle I was using to rotate the belt tensioners to provide more leverage and access. I hope you can pass all your labor costs for that machine work on to your customers.
The following 4 users liked this post by Hartwig:
The following 3 users liked this post by Hartwig:
#29
The following 2 users liked this post by Hartwig:
#30
I was struggling again with a non-magnetic IPR valve screen that was difficult to get out of the HPOP.
I don't know why the screens have different magnetic intensities.
On the early 6.0s with the rear bridge on the intake manifold, this is often a very time intensive job.
I have now built this tool.
The following 5 users liked this post by Hartwig:
