so, when pulling a trailer and making a turn, I feel chattering coming from the rear axle. Have driven truck for 50-70k with the limited slip carrier (taken from a crashed truck) with no issues. I can only feel it with a load or trailer attached and it just recently started doing this.
I removed and disassembled the carrier to inspect the clutches,, they appear to need replaced, but not metal on metal, yet. Reassembled and installed for now.
Also found the drive line carrier bearing rubber boot allows me to shake the drive shaft more that’s I think it should.
First question,, do you think the chattering I’m feeling is the bad clutches? Or carrier bearing on drive line?
Second,.. where can I find a carrier clutch rebuild kit under $300 (seems pricey).
Third…if drive shaft carrier bearing needs replaced,, price for the bearing?
If you have chattering while turning in the limited slip you likely do not have the proper amount of limited slip treatment in the rear end oil. Get a bottle of limited slip friction modifier and follow the instructions on it.
Also you should not have any play in the drive shaft, if you can move it by hand check the carrier bearing and the U-joints. None of it is a hard fix but the joints will cost you about $100 each for quality parts.
Thanks for the info.. u-joints are solid, no “play” in them. Carrier bearing rubber housing has lots of movement. Bearing seems ok, just the rubber dampener seems bad and need of replacement
When you say the rubber damper seems bad...is it broken and or deteriorated cause mine is not broken and seems to have some movement which I think is ok.
Have you done a rear end fluid change recently? If not, I would start there using new gear oil and up to 8oz of friction modifier. Some oils do come with friction modifiers already included in the oil but I find that you might still need some.
Added a bottle of modifier several weeks ago, no change. May need more… what puzzles me it wasn’t doing this, then suddenly started chattering / jerking. I may try changing the oil..
I’d be willing to agree the carrier bearing rubber has some deterioration due to its age. So, prolly will replace as a precaution
Is it possible your rear tires are gripping/scrubbing with the added weight on the rear?
I used Amsoil gear oil my first time I changed the fluid. It claimed to have friction modifier in it. I had to put a full bottle of XL-3 into the differential anyway to stop the chattering/binding.
I have changed it twice since then and no additional XL-3 has been added. I suspect the residual fluid from the first change was not providing enough "friction modifier". Add it slowly and test it out after each dose.
