Pinion seal
Old Sep 16, 2021 | 08:05 PM
Broncor's Avatar
Broncor
Pinion seal
Hello all, the mighty ford keep trucking along but I have fluid randomly burping out of pinion seal.
88 f150 5.0 5 speed.
I put a new seal in rear pinion about 2 years ago. I cleaned up vent on diff and ran it up tied of into rear frame. Put a filter on end of hose.
The pinion has seeped fluid out fairly regular when parked since the change.
I guess I’ll have to replace and would like to do so soon.
Is there anything I should do differently this time ? Things to look for ?
I just pull drive shaft it should be right there ?
Any sealant this time ?
thanks for for your thoughts.
Old Sep 16, 2021 | 08:16 PM
Edgethis's Avatar
Edgethis
To get the pinion seal off you'll have to pull the yoke. Sealant probably won't help since it's a rotating part. One thing to look at is your yokes condition. On a part this old it could have a groove worn into it. If that's the case a new seal will still most likely leak. You would either need to look and see if they offer a seal with a different tolerance designed for a worn yoke or replace the yoke and use a normal seal.
Old Sep 16, 2021 | 10:08 PM
Broncor's Avatar
Broncor
Yikes ok thanks, wouldn’t surprise me if yolk didn’t have a groove in it.
Maybe other solution is top up fluid every now and then …
Thanks edge
Old Sep 16, 2021 | 11:21 PM
85e150's Avatar
85e150
Seal the splines too.
miottimouse
Aug 21, 2013 11:08 PM
61 uni
16
Mar 13, 2009 05:42 PM
73FOMO
Mar 20, 2006 05:06 PM
bighoss550
Apr 18, 2005 10:06 PM
dash riprock
Aug 23, 2002 07:13 PM
