multifunction switch
Old Aug 30, 2021 | 06:42 PM
obsxl's Avatar
obsxl
so in looking around on different websites for multifunction switches for our trucks, I noticed most places offer one that says “with electronic flasher” and one that says “without electronic flasher.” anyone know what that’s about?
Old Aug 31, 2021 | 08:34 AM
BlackBeautyFlareside's Avatar
That seems odd. On all three of my OBS trucks, the flasher button is part of the multifunction switch. You can pull the plastic cover off around your steering column and check out if yours is integrated into the switch. The cover comes off in five minutes with four Philips screws and an allen wrench or awl to get out the ignition switch.
Old Aug 31, 2021 | 10:11 AM
obsxl's Avatar
obsxl
I’m sure mine is too, but I’d have to check. The weird thing is all of them have the hazards button and look the exact same. I might have to go down and check them out in person when I get the chance
Old Aug 31, 2021 | 11:02 AM
wwhite's Avatar
wwhite
Are they referring to 'electronic' as in a chip or silicon, transistor is controlling the flasher?
Where 'without', could be a mechanical coil relay type flasher?
Old Aug 31, 2021 | 11:48 AM
obsxl's Avatar
obsxl
I really don’t know, nobody elaborates on that. But I wouldn’t think you’d need two different switches for different flashers
Old Sep 1, 2021 | 10:41 PM
AuroraGirl's Avatar
AuroraGirl
Why not just get the motorcraft one and save yourself the worry, it says without electronic flasher.
https://www.fordpartsonsale.com/oem-...U0VPIFBhZ2U%3D
SW5591 - Motorcraft
F8tz-13k359-ab - Ford
I have one on my shelf waiint for me to put it in ,its been only a couple years now lol.
Old Sep 1, 2021 | 11:17 PM
obsxl's Avatar
obsxl
SW5591 - Motorcraft
I called the local Ford dealer and they didn’t have it, he said they were backordered but he had a different part # for it than the one you showed. I don’t even know if the switch is the problem or my wiper module so I’m not gonna replace it just yet. That one also says without tilt steering?
Old Sep 2, 2021 | 01:59 AM
AuroraGirl's Avatar
AuroraGirl
i have never had a truck or been around an obs with tilt steering so I guess I didn’t realize they are different. Maybe a tilt wheel has the mfs follow it’s rotation? Oops tho ignore me. But it’s right for my truck then lol
Old Sep 2, 2021 | 02:01 AM
AuroraGirl's Avatar
AuroraGirl
there is a testing procedures with dvom tht can deterkune if mfs, wiring, or the wiper module. Or motor. I guess. Go pull your right side kick panel and glovebox and make sure it’s connected and no issues. Grounds. Etc
Old Sep 2, 2021 | 09:22 AM
obsxl's Avatar
obsxl
I plan to pull the module and open it up to see if I can see anything wrong...someday
mcanik
2009 - 2014 F150
May 10, 2017 08:39 PM
firewood truck
Mar 17, 2012 01:46 PM
Ole'Blu
Dec 10, 2006 12:55 AM
MufassaMaxx
Jun 9, 2002 11:02 PM
Bob R
Oct 4, 1999 07:54 PM
