tailgate latch assembly broke.
Old Aug 28, 2021 | 09:05 AM
dremtofford's Avatar
dremtofford
i went to close my tailgate the other day and it wouldn't latch. took a look-see at it and there was a broken torque bolt jammed into the latch assembly bending it all up. i haven't been able to find a new one yet or any good old ones. the ones in the wrecking yards are broken or missing and nobody sells new ones. so far bungy cords work but look crappy and unsafe.
Old Aug 28, 2021 | 11:33 AM
sandymane's Avatar
sandymane
See if LMC FORD has what you need.
Old Aug 28, 2021 | 01:30 PM
dremtofford
tail gate latch
they do but it is 80.00 bucks each. that is above my paygrade.
Old Aug 28, 2021 | 01:44 PM
TexasGuy001's Avatar
TexasGuy001
I see Dorman replacement latches for 50 bucks on Rock Auto.
https://www.rockauto.com/en/catalog/...gate+latch,846
Old Aug 28, 2021 | 01:58 PM
SFaulken's Avatar
SFaulken
I'd go pull one out of a junkyard tailgate, before I'd spend money on anything with Dorman on the package.
Old Aug 29, 2021 | 09:57 AM
dremtofford
Originally Posted by SFaulken
I'd go pull one out of a junkyard tailgate before I'd spend money on anything with Dorman on the package.
i agree with you dorman last long enough to break first-time use.
Old Aug 29, 2021 | 11:57 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by dremtofford
…and there was a broken torque bolt jammed into the latch assembly bending it all up.
A broken Torx bolt? Do you have bigger problems- like where did that come from and can you get the rest of the bolt out from wherever that is?
I agree on getting an OEM one from a junkyard before buying aftermarket.
Old Aug 29, 2021 | 12:16 PM
torq'ta 5 8's Avatar
torq'ta 5 8
My 95 has a 'git to latch panel'(that's not right?) it has those big head torx bolt
Old Aug 30, 2021 | 11:32 AM
AuroraGirl's Avatar
AuroraGirl
what year? i do think they revised the latch system in the late 80s and the beds swap, so jsut making sure we are on the same page. YOu mean the side of the tail gate, right? The spring and the catch that then grabs the bushing-having striker on the bed side?
Old Aug 31, 2021 | 02:30 AM
TexasGuy001
Not everyone has the time or ability go to a salvage yard.
I generally prefer original parts, but don't think Dorman is all that bad, and it is better than not having any new parts. Most parts trucks are junk and tailgates are the first things gone around here.
Old Aug 31, 2021 | 11:24 AM
SFaulken's Avatar
SFaulken
Dorman is garbage. Period. And I won't recommend them, or even suggest that they're ok, especially to people that don't know any better.
I worked in Auto Parts for way too many years, and dealt with their poor quality control, and overall "build to the lowest price point" practices that it's a hill I'm willing to die on.
Old Aug 31, 2021 | 06:42 PM
AuroraGirl's Avatar
AuroraGirl
ive gotten things from dorman usually help section items and they are OK. Caliper bracket bolts, OK.
Quality control? Damn straight, get a tensioner from them i feel like its about 1/5 it works or doesnt bend doing its job
Put a balancer on my buick from them. SURPRISINGLY its still ok. def would go for the ac delco but 300 dollars vs 100 in a pinch was sure painful choice
Old Sep 1, 2021 | 01:09 PM
dremtofford
the bolt looks like it came out of the latch to bolt it to the tailgate the internals of the latch was all bent up because the previous owner tried slamming the tailgate when it wouldn't latch. so i tried to straighten it but that didn't work.
Old Sep 1, 2021 | 11:09 PM
AuroraGirl's Avatar
AuroraGirl
is it bent or is it pushed over? I had mulch and debris I dumped out one day stick in there and just pushed the parts away and a little bit of digging out and a small screw driver i wasable to clean it out and put it back
Old Aug 21, 2022 | 07:51 PM
dremtofford
yes the parts on the side of the tailgate. and yes they are all bent up.
Bret4207
Jun 26, 2021 04:42 PM
97biostroke
May 4, 2011 05:37 AM
Ford1988Trucker
Aug 3, 2010 05:02 PM
fordbroncodave
1978 - 1996 Big Bronco
Jul 31, 2009 11:43 PM
heppjay
Oct 9, 2003 06:15 PM
