Mustang 5.0 swap into 94 f150
Originally posted by flamed79
I JUST DID THE SWAP MYSELF, I USED THE MUSTANG LONG BLOCK AND SWAPED THE INTAKE, OIL PAN, VALVE COVERS, DISTRIBUTOR, AND FRONT ACCESSORIES, AND USED THE HO FIRING ORDER , I'VE DONE A BUNCH OF MOTOR SWAPS, IT WAS DONE IN A DAY... (I WISH THEY WERE ALL THIS EASY)
The heads on the mustang 5.0L HO are even D7 heads, wich are truck heads designed for torque, the mustang cam utilizes that torque by bumping it up into a higher rpm range for car purposes. Yes the trucks have solid lifters because they arent meant to rev high on a daily basis like the mustang engine. Yes the intakes are different because its a mustang not a f150, the plenum&runners need to be designed to the meet the demand put on the engine. Yes you wasted money, you could have done that conversion by simply buying a mustang wiring harness, intake, roller lifters and camshaft.
at least you didnt buy it then. You are right they are E7s, all fox body mustangs with the HO engine simply only had truck heads. Be careful with mixing cams with intakes on EFI engines, intakes are designed in co-ordinance with the longblocks power output. This is why the mustang 5.0L had more power then the truck's engine. There is alot more depth i could get into about runner length and plenum size, runner length is determined by where the power needs to be and how high the engine has to rev (shorter runners higher revving) and plenum size is determined by rpm and runner size in cfm, the runners will flow a certain cfm and hold a certain cc volume, the plenum needs to be just under 50% of combined runner cc's
Originally posted by pud
the mustang long block and the truck block are the same. The only difference is the mustang will have roller lifters and a different cam. Whatever you paid for the mustang blocks, think of the amount of parts you could have bought instead
on
Yeah that is fairly obvious because you dug up a thread from 2003 to post your question in. It's good that you are reading old threads because there is lots of great info in them that still applies but you should create your own thread from scratch and give it a title that reflects your question. Just go to the top of this section and you will see a button for creating a new thread.
getting ready to pull the tired old 5.0 out of my 85 it the first gen EFI
i have a good 1995 5.0 out of a f150 .
it is a roller block and ran great when pulled. used the heads on another project a while back.
any recommendations on what to do to this thing before i throw it back in?
i have a stock heads i just bought that have been gone through tanked beaded new valves and springs the whole shot.
Should I stick with these?
should I throw a E303 cam in it ?
how about a MSD distributor? Do you really get anything extra for the $400 price tag of the MSD distributor ?
I also have a set of mustang stock headers I was throwing at it are they too small? Should I go with aftermarket headers?
trying to do this on a budget cheap as possible but properly
I know for sure the rotating assembly is excellent shape.
and plan on doing full set of new fel pro gaskets and new melling oil pump
with a Cloyes double roller timing chain.
on
getting ready to pull the tired old 5.0 out of my 85 it the first gen EFI i have a good 1995 5.0 out of a f150 .
No.. it's not a truck friendly cam.
Good, just do not use a high volume pump there is no need.
#29
