Not Another Oil Thread
Old Aug 13, 2021 | 11:29 PM
Brian Hanks's Avatar
Brian Hanks
It’s an auto. But I was told by a friend who has been a Toyota mechanic for 30 years and a good mechanic on side.. not just dealership ... that that particular transmission locks TC only in OD and when shift to 4 manually it can help diagnose a very common issue with that model being the TC. It immediately did as he suggested and you can’t get it to slip or stutter unless back to OD. Flush and modifier fixed it or at least put a decent bandaid.
read on Toyota forum a description by someone akin to a Mark here that said the TC will start to get glazing and if you catch it soon enough a change and specific additive can potentially rehab it if caught in time. So far so good. Apparently they replace tons of just TC in these transmissions to fix this common issue and don’t do rebuilds and they are good to go. Not sure of root cause but really seems like a flaw in design somewhere.
btw. Sorry for the hijack
Old Aug 14, 2021 | 12:58 AM
F350towing's Avatar
F350towing
No problem on the hijack. After all we’re still talking about oil changes, and intervals. Maybe not the motor, nor a 7.3, but one day this will be useful to somebody considering the stuff I’ve found from a simple google search. Sometimes in the least expected- oddest places we find a nugget of knowledge.
Old Aug 14, 2021 | 07:20 AM
RacinJasonWV's Avatar
RacinJasonWV
Brian it now sounds like you are describing TC shudder. Yes absolutely makes sense now. This isn’t ‘slip’ but more of a clutch chatter (picture a manual with chatter). TC LU designs have moved to include partial Lock Up conditions which are basically controlled slip to allow better fuel economy.
And sorry, I got that it was an Auto. Not sure what I said wrong that made it sound otherwise. Probably my poor quick description of the TC LU function. I’ll try to explain it better (if anyone cares lol). Normally the TC slips as the 2 fans are making a fluid coupling. This fluid coupling is required to allow stopping while in gear (engine at idle speed, Input Shaft at zero). Otherwise it would stall like a manual. Once up to speed this equates to loss of efficiency (1 revolution from engine = less than 1 going into the trans). The TC LU clutch will engage to make it become a 1:1 condition and get rid of the slip of the fluid coupling.
And yes, sorry for the off topic discussion.
Old Aug 15, 2021 | 12:21 AM
binuya's Avatar
binuya
Originally Posted by F350towing
Does oil actually break down just sitting in the pan waiting to be used? I’m no scientist but I find that hard to believe.
I had often wondered about the time aspect of OCI's, especially since my PSD often sits several weeks to over a month without use. I typically average less than 2500 miles per year. Several years ago I sent an oil sample to Blackstone, and asked whether or not I should be concerned about a longer than average time interval. Besides having a good report, they basically said keeping it in use for a few years is a non issue.
https://www.blackstone-labs.net/BSto...spx?cid=G02286
ford390gashog
2015 - 2020 F150
Apr 18, 2020 02:10 AM
kurthb
Sep 8, 2018 04:19 PM
82_F100_300Six
6.2L V8
23
Jul 24, 2018 06:20 PM
T Webber
Sep 12, 2014 12:21 AM
acf6
Jun 25, 2012 04:28 PM
