Sponsored by: Real Truck
electric fan
Old Jun 9, 2021 | 10:51 AM
ibfishing's Avatar
ibfishing
electric fan
Has anyone installed an electric radiator fan on a 99 f250. I am doing an engine swap and was considering a change to an electric fan. Any suggestion as too one that is under 150.00? I read that a Taurus fan was adapted and it works well.
Old Jun 9, 2021 | 11:09 AM
ford390gashog's Avatar
ford390gashog
What gain are you looking for? The stock clutch fan will pull more air then any electric fan you can fit in there.
Old Jun 9, 2021 | 11:48 AM
ibfishing's Avatar
ibfishing
The biggest reason is easy access for repairs. From what I am reading I may stick with stock.
Old Jun 9, 2021 | 02:25 PM
FiveOJester's Avatar
FiveOJester
Unless you never work your Superduty hard or tow anything I would leave the stock fan. I haven't seen any electric fans on the market that can flow anything near what a good large mechanical fan can do. Then you would also need alternator capacity. Probably need a 300-400 amp alternator just to run the thing.
Old Jun 10, 2021 | 08:29 AM
ibfishing's Avatar
ibfishing
Thanks for input, i think I will just stay with the stock!
Old Jun 15, 2021 | 09:00 PM
Byrd.Dog's Avatar
Byrd.Dog
Only good reason for going with electric is if you're limited on space.
Hongster
Jan 30, 2012 06:47 PM
TheTowingCowboy
29
Jun 18, 2010 04:13 PM
boxer.fan
Jun 12, 2008 08:26 PM
Lone_Ranger01
1983 - 2012 Ranger & B-Series
Apr 8, 2004 07:22 PM
