1978 - 1996 Big Bronco
ignition switch
Old Oct 29, 2003 | 04:43 PM
b-annie's Avatar
b-annie
ignition switch
recent new 1978 ford bronco owner! first fix - need to replace ignition switch ! Someone told me I need to pull steering wheel, is that true? Help me please!!!
Old Oct 29, 2003 | 09:21 PM
fordguy351w's Avatar
fordguy351w
it all depends. is it manual or automatic? if its manual yes you will have to pull the wheel. if auto all you have to do is turn the ignition(using keys) and use a nail or something small to push the "button" under it. it shpuld be just a little hole on the bottom of the ignition. manual is just the same except the hole is inside. hope this helps
Old Oct 29, 2003 | 09:42 PM
christop43's Avatar
christop43
Isn't the ignition switch for 78-79's in the dash? At least I think it is.
