My new to me 1995 ford f250 4x4 has man lock in hubs, I just noticed the transfer case has a shift motor. but it is unpluged and has been for a while. I haven't seen and loose wires in the harness. So has the transfer case been changed. I have the 4x4 stick in the floor but no switch.
Better verify your floor shifter is actually connected... Sounds like someone shoved a ESOF transfer case to solve a problem and it's no able to be shifted.
I checked the floor shift when I got the truck. It was pretty easy to engage but I like to never got it to disengage. I checked the tag but I know it could have been changed. I look for numbers on the case. Here's a picture of the plug I was talking about.
Yeah that is not an ESOF transfer case. The shift motor is much bigger than the speed sensor you see. It's the same size and shape as a power window motor and goes where that recessed place is in your pic with the white dirt in the hole.
