F550 towing build thread
Old May 28, 2024 | 04:54 PM
  #481
RacinJasonWV's Avatar
RacinJasonWV
Originally Posted by Hvyhaulr
next set of mods will be brakes. What do you guys recommend for kickass towing brakes for hauling loads? I don’t care about brake dust or noise, I just care about performance. Let me know your thoughts.
@SkySkiJason has some strong opinions on brakes. And he has the experience to back it up so calling him in for his words of advice. I’m pretty sure he says EBC Yellowstuff.
Old May 28, 2024 | 04:58 PM
  #482
jstihl's Avatar
jstihl
Hey guys, update here. Got my DIY exhaust brake in. I’ll be testing it this week/weekend.
I drilled a tiny hole and then a 1/2in hole. So far I’m seeing 21ish lbs of back pressure unloaded when it’s fully closed. It usually is near zero back pressure until like 70% closed. Maybe I went too big on the 2nd hole. Not sure but we will find out!
Curious what you used to weld the exhaust pipe up? As far as brakes go I use EBC yellow stuff on my f-450 for hauling heavy loads and they seem to do pretty well
Old May 28, 2024 | 05:25 PM
  #483
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Hvyhaulr saw the post, liked it, but didn't answer.
So.. it's game on. Guessing game, that is.
My guess is that it was back step welded (based on the starts and stops) to mitigate heat distortion, using a wire feeder, in spray mode, with a pulse waveform. (GMAW-P)
Old May 28, 2024 | 06:04 PM
  #484
Hvyhaulr's Avatar
Hvyhaulr
I look forward to what he says. I did research on brakes and I read so much stuff on “these work but it’s noisy or too must dust” idc. I just want to stop well. lol
how about rotors? I need those too.
just mig welder, regular old wire. I’d say these are more robotic looking and less like a normal weld. I didn’t do much “C” action because the flange was so thick I concentrated on the flange and the puddle spilled onto the thin exhaust tubing
glad to hear EBC is good stuff. How about rotors
Old May 28, 2024 | 06:30 PM
  #485
jstihl's Avatar
jstihl
Ok I was curious because I was going to attempt to weld some of my exhaust when I install my aero turbine muffler but heard it can be a pain to weld. As far as rotors I've always just used motorcraft because I have a commercial account with a local dealer. I get the heavy duty version and have never had any warp under really hard braking conditions while hauling. EBC yellow stuff has great breaking power but they do seem to wear out rotors faster than other pads. It's a pick your poison kinda thing . I'm sure others will chime in with some advice on what they like as well
Old May 28, 2024 | 09:55 PM
  #486
Hvyhaulr's Avatar
Hvyhaulr
I hate exhaust work with a passion and I’ll say the 4in exhaust from summit wasn’t as thin and terrible as others I’ve used in the past. I think that helped a ton
Old May 29, 2024 | 08:13 AM
  #487
SkySkiJason's Avatar
SkySkiJason
Welds look great. I’m anxious to see how you like the exhaust brake!!!
100% EBC Yellowstuff. There is no better pad for braking authority. I shop around for best prices. ALWAYS look at ‘available from other sellers’ from Amazon. ‘Used’ will be a return item and I OFTEN buy these at 40% off for F250/350.
Amazon Amazon
Only ‘lifetime warranty’ rotors from Napa (Adaptive One line). Rotors are wear items. The more expensive stuff is mostly gimmicks or the same or even cheaper crap with holes in them in a fancier box with red-painted calipers...
https://www.napaonline.com/en/p/UP_86924CR
Old May 29, 2024 | 09:56 AM
  #488
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If you are replacing the rear rotors as well, stick to Motorcraft. They are the only rotors (pretty sure) that has a textured surface on the inside of the hat to aid in holding the parking brake when set. Many of us have had good luck with Hawk SD pads too, but they are not the EBC Yellow Stuff pads by any means.
Old May 29, 2024 | 10:37 AM
  #489
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
I feel this fits this thread
Old May 29, 2024 | 11:09 AM
  #490
jstihl's Avatar
jstihl
Wow!! 😳 That is pretty crazy. So I guess we are kinda screwed when it comes to brake components
Old May 29, 2024 | 11:11 AM
  #491
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Just buy Motorcraft.
Let Ford do the supplier vetting.
Old May 29, 2024 | 11:24 AM
  #492
ESwift's Avatar
ESwift
CNCFAB
I have been happy with my EBC yellowstuff pads and EBC dimpled and slotted rotors.
My next brake job will be the beefy SSBC calipers and pads
Old May 29, 2024 | 01:25 PM
  #493
FordTruckNoob's Avatar
FordTruckNoob
You're going to love the SSBC calipers. May I suggest these pads though:
Amazon Amazon
The Hummer H2 uses the same size pads if you want to shop for other brake pads.
EDIT: Put anti-sieze on the threads of the bleeder nipples. Steel nipples (BCBW) in aluminum calipers tend to get stuck.
Old May 29, 2024 | 10:37 PM
  #494
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
When considering the SSBC calipers I called to ask what kind of pads came preloaded. All they could say was "good ones", so I got some Hawk LTS pads on hand. When they arrived I was surprised to see they were loaded with Hawk SuperDuty pads. Since I already had the LTS pads on hand I saved the SD pads for later. And I found them after moving twice!
No idea if they were standard at the time, or what pads they come with now.
Old May 30, 2024 | 05:06 AM
  #495
jstihl's Avatar
jstihl
@aawlberninf350 did you find these calipers for your f-550? I've been looking for some for my f-450 and haven't had much luck. I emailed ssbc and they sent me a part number for a 2017-2022 f450 by accident and still haven't heard back from them
