Sponsored by: Real Truck
Drive shaft help
Old Apr 20, 2021 | 09:22 PM
Kalslade3's Avatar
Kalslade3
Drive shaft help
I am currently swapping my 99 f350 7.3 crew cab long bed with a 172 wb to a single axel, the problem I have is I'm using a 99 f250 4x4 supercab long bed axel in the rear and the u joint on my current drivshaft is too big to fit the new axel, so I'm wondering is there a length difference in the f250 drive shaft since I can't swap the yokes from my old dana 80 to the new axel off the f250. Thanks in advance
Old Apr 21, 2021 | 12:41 AM
WWR's Avatar
WWR
Don't know about length but have you pursued a crossover joint? 1330 to 1350 definitely available as is 1350 to 1410.
Measure cap dia and distance across caps to figure out the size presently in your d/s and the size that needs to go in the yoke
Old Apr 21, 2021 | 05:19 AM
Kalslade3's Avatar
Kalslade3
So I bought the yoke to change it to a 1410 like suggested but as I was looking around I was looking at drjveshafts on rock auto and decide the my drive shaft is Dorman 946438(84.3 long) and I think the correct swap drive shaft being Dorman 976364 (89.3long) with that extra length be needed in my shaft or no because the new one is a 5.4 drive shaft so length will change at the trans hooked up not how long the yoke and hole axle assembly is compared to my current dana 80
96ford250
Feb 25, 2013 09:39 PM
ebaugh90
6.7L Power Stroke Diesel
May 8, 2011 03:14 PM
JaysRanger
Jan 21, 2010 12:39 AM
