Replacing VC Gasket
Old Apr 17, 2021 | 12:54 PM
SpeedThrills's Avatar
SpeedThrills
Replacing VC Gasket
The (original) 300 in my 95 F150 needs a valve cover gasket. Other than that gasket, and the upper to lower intake gasket, is anything else needed? I don't want to dig in and find I need something else.
Rockauto shows them from $4 to $22. Who makes good ones?
Old Apr 17, 2021 | 09:14 PM
john jamieson's Avatar
john jamieson
Some people swear by cork. The kit for my current build is a Felpro, and it is silcone???
Old Apr 18, 2021 | 10:46 AM
SpeedThrills
Thanks, John.
Old Apr 24, 2021 | 06:51 PM
AbandonedBronco's Avatar
AbandonedBronco
By 95, they were all silicone. The bolt hole sizes are smaller on the newer valve cover, and it uses compression rings around the holes to help seal. I don't think there's a cork gasket available.
You don't necessarily need to do it while you have the valve cover off, but while you're in there, I'd also do the pushrod cover gasket on the driver's side of the engine. It's a source of a lot of leaks and is inexpensive and easy to replace.
Old Apr 24, 2021 | 09:04 PM
SpeedThrills
I started this today. I ordered a pushrod cover gasket. It's leaking. I cleaned the engine, and that made the leak obvious.
Thanks
amish77
Aug 16, 2010 11:22 AM
rushinriver
Nov 23, 2007 06:43 PM
straight 6's
Jun 16, 2004 09:43 PM
voodoosurfer
Dec 2, 2003 12:29 AM
erikl85
Nov 15, 2002 05:47 PM
