Sponsored by: Real Truck
1999 v10
Old Mar 2, 2021 | 08:58 AM
Awbucco9's Avatar
Awbucco9
1999 v10
My v10 has had a weird idle for awhile where it idles up a couple hundred rpm and then it sounds like something clicks and it goes back down and does it over and over again, no clue what it is, it recently has been whistling and the whistle is high pitched and follows the idle (going up and down) when truck is sitting, any advice would be appreciated.
Old Mar 2, 2021 | 12:28 PM
redford's Avatar
redford
FTE Leadership Emeritus
Check or clean your Idle Air Control valve. Good place to start, anyway.
Old Mar 2, 2021 | 05:55 PM
irydasteelhorse's Avatar
irydasteelhorse
if you have the AC on, or the defrost, your AC compressor will kick on and off and the idle will adjust for that. that accounts for the click sound also when it engages the compressor.
whistling sounds like a vac leak, or intake leak.
HMS
May 24, 2020 11:18 AM
oct7brian
Mar 27, 2006 07:20 AM
Budkole
Mar 25, 2004 06:42 PM
NoMo
Jan 12, 2002 08:16 AM
