wheels
Old Feb 19, 2021 | 05:29 AM
lomesome1's Avatar
lomesome1
Smile wheels
I have another question, sorry, If I put the crown vic front end in my 56 do I have to use those kind of wheel or can I use reg. wheels?
Old Feb 19, 2021 | 06:11 AM
Marten's Avatar
Marten
As long as the bolt pattern works you are good with any wheel. Some rims also require hub centric rings, something to watch out for. Just learned that myself.
Old Feb 19, 2021 | 08:08 AM
EBEAR's Avatar
EBEAR
Unless you are using a narrowed cv you will be limited to the high offset like the cv factory wheels . I believe some use Mustang wheels .
Old Feb 19, 2021 | 08:41 AM
lomesome1's Avatar
lomesome1
Is this because the wider track, I wonder how these old trucks handled new, I think might been pretty bad. think it would be better to up grade the brakes and just put tbird rear under it. Sorry for asking so many questions but thats one way for people to learn. Thanks
Old Feb 19, 2021 | 09:01 AM
EBEAR's Avatar
EBEAR
Don't apologize for asking questions . This is by far the best site I know of for help and support which in turn results in allot more finished projects instead of abandoned frustrated attempts . And yes the width is the issue . I would suggest finding someone with a good rebuilt or slightly upgraded front end and convince them to let you drive it . This will give you a good handle on what you will find acceptable .
Old Feb 19, 2021 | 12:06 PM
GLR's Avatar
GLR
Don't forget that you need the spacing to allow for the disc brake calipers.
Old Feb 20, 2021 | 07:02 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
My suggestion is to find a truck show close to you and attend it. Most folks don’t mind telling you what they did to make things work. There’s a smaller show in Branson, MO 16-17 July, The Ozark Mountain Run that might not be that far from you. But if you really wanna see some trucks attend the Grand Nationals or Super Nationals both in or around Pigeon Forge, TN. Their both on the web.
The Crown Vic thing is an either or. People love them or they hate them. You’ll get every answer in the book on if they fit. Tire selection is limited because of the offset needed but believe me there are plenty of rims you can buy for them.
Old Feb 20, 2021 | 11:00 AM
lomesome1's Avatar
lomesome1
I thought about getting a dropped axle from speedway motors, Have to see if anyone builds hubs with 5 on 4.5 bolt pattern that will fit the stock spindles since I'm going to use the tbird 9 in.
Old Feb 20, 2021 | 11:06 AM
bjmayberry2
If you want a dropped axle contact SIDS in Guthrie, OK.. https://droppedaxles.com/ I’m pretty sure he can answer your hub question as well.
Old Feb 20, 2021 | 03:00 PM
bigwin56f100's Avatar
bigwin56f100
I have a set of adapters that bolt onto the stock 5x5.5 pattern and then gives you the 5x4.5 pattern for wheels to bolt on
Old Feb 21, 2021 | 07:43 AM
lomesome1's Avatar
lomesome1
After thinking about it I have decided to put the crown vic front end and the thunderbird rear since I already have both .the bird rear is the same width as the truck. Someone wrote on here about some loving the crown swap and some hate it. would like someone who has done it to tell me the pros and cons. Again thanks for the help
Old Feb 21, 2021 | 09:26 AM
56panelford's Avatar
56panelford
You can spot a Crown Vic swap right away on these trucks because the the tires are on the outer limits and almost contacting the fenders, it's done because it's a cheap alternative of a new cross member. I've never done a Crown Vic and will never after dealing with a frame swap I did when not calculating the tracking width. If I had bought an aftermarket cross member in the first place with what I spent to correct it I could have done the next two builds. Big plus also is you have hundreds of wheels to choose from..live and learn..
Hope whoever has done it gives you honest feed back..
old_dan
Apr 9, 2016 12:34 PM
PFranko
Mar 8, 2016 10:02 AM
48fordcoe
Jan 11, 2011 08:41 PM
Pauls47
1947 and Older Ford Trucks
Sep 3, 2010 11:02 AM
mark-in-wyoming
Jun 3, 2006 10:56 PM
