Rear Axle Code Info Required
Old Jan 24, 2021 | 08:20 PM
habbythetabby's Avatar
habbythetabby
Hello folks. Just a question on a rear axle metal tag that shows the following info: First line: WDM C; Second line 3.70 A7S
Hopefully NumberDummy can decipher this for me. It's on an rear differential assembly that I just acquired, presently under a 1964 Mercury M100 Short Box. This tag info does not match what's shown on the VIN plate at the door location, so I doubt that it originally belongs to this truck.. Vin plate shows 3.92.1 What year of truck would it be from?
Thanks for any hep you can give me.
George
Old Jan 24, 2021 | 08:29 PM
85e150's Avatar
85e150
WDM C with a 3.70 ratio showing is from a '63 to '72 F100. 28 spline axles, non-limited slip.
A7S Doesn't decode to a date code afaik, maybe a plant code.
https://www.fordification.com/tech/rearends_ford01.htm
Old Jan 25, 2021 | 07:54 AM
habbythetabby
Hi and thanks for the info. Yes, it's the A7S that is a mystery to me too. It would appear that somewhere in the past, the entire rear differential has been changed from the 3.92 Dana/Spicer type(shown on the door) to the 3.70 Ford type(shown by the tag).
mtpcage
2004 - 2008 F150
Jul 26, 2010 02:04 PM
pelletman
22
Jan 15, 2007 09:16 PM
MikeSDK
Feb 14, 2006 02:09 PM
kaitykaity
Oct 27, 2005 06:05 PM
quadna711
Mar 24, 2001 09:12 AM
