Engine Miss While Accelerating
Old Jan 14, 2021 | 08:00 PM
Old1990Truck's Avatar
Old1990Truck
Question Engine Miss While Accelerating
I have a 1990 f-150 with a 4.9l. The engine has an intermittent miss while accelerating after the transmission shifts up a gear (second and third only). KOEO and KOER both read a passing code 11. Engine compression is good, around 155-160 psi measured in each cylinder. TPS and MAP both tested ok. The plug wires, distributor cap, spark plugs, injectors, fuel filter, both vacuum reservoirs, and upper intake manifold seals were replaced within the last 2,000 miles. Also, switching between fuel tanks didn't change anything. I don't currently have a fuel pressure gauge and none of the local parts stores have rentals available, so that is about the best I have been able to do. At this point I have no idea what could be causing it besides a darn gremlin ! Any help would be greatly appreciated.
Old Jan 15, 2021 | 12:51 AM
Flyinbolts's Avatar
Flyinbolts
I just went thigh this, still slightly fighting it with my 4.9
i went through 4 coils and finally got one that works decent (ngk)
also replaced cap rotor wires plugs before hand.
Old Jan 15, 2021 | 12:22 PM
Old1990Truck
Thanks! I tested the ignition coil's secondary coil resistance. It was about 600 ohms low of spec. It was replaced. I also went through all the ground cables I could find in the engine bay and cleaned them. Took it for a drive and the miss seems to be gone! If I had to guess it was a combination of a bad ecm ground and the coil pack.
Old Jan 24, 2021 | 10:02 AM
Old1990Truck
Well, after driving it around for a week the miss is back. I tried cleaning all the grounds again and adding dielectric grease to prevent possible corrosion from forming. I disconnected the power while doing this. After taking the truck for a drive, the miss was gone but showed up after the computer worked itself in. Could this be a computer issue? The grounds seem solid now and it doesn't feel like a broken wire.
Old Jan 24, 2021 | 05:08 PM
midwestbird's Avatar
midwestbird
This may not be your problem, because I experienced a misfire only at idle. But, my ignition control module suddenly died in December and after I replaced the ICM, my idle misfire went away. The local AutoZone has a machine to test an ICM, but not sure if it'll test as faulty if it's not completely kaput.
Old Jan 24, 2021 | 05:14 PM
midwestbird
leaky capacitors in the eec-iv have been known to cause odd behavior. In my case, it caused my truck to buck wildly as I accelerated. Turned out to be leaky capacitor. Replaced the eec4, and problem solved. Won't hurt to take a peak, a leaky capacitor is easy to spot.
Old Jan 24, 2021 | 08:53 PM
Old1990Truck
I'll have to try looking at the computer soon. I believe the computer is original to the truck, so it wouldn't surprise me if a cap or diode blew. Thanks for the help!
KMag1226
Nov 11, 2018 07:44 PM
danmm7
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
22
May 28, 2018 12:53 AM
87thhunter
Mar 21, 2014 08:02 AM
willys59cj5
Jan 18, 2007 12:21 PM
chollas
Bronco II
Dec 5, 2005 07:06 PM
