97 460 tuning
Old Jan 14, 2021 | 07:47 PM
Sam Rogers's Avatar
Sam Rogers
97 460 tuning
My 97 f350 has an EEC-IV or EEC-V ( not sure which just know it's an EEC and not OBD) and I'm really interested in tuning to gain some power. I've seen the tweecers and quarterhorse but they seem waaay to complicated. I was wondering if it is possible to get an EEC to OBD adapter and use a regular tuner? I know that most tuners are engine specific but are there any close enough to work anyway?
All help or advice appreciated!
Old Jan 15, 2021 | 04:53 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Should be, OBD I, unless Cali Truck, two members just installed, Pimpx, so depending on which Trans, you have
easy button-->PiMP Standalone ECU's & Tuning Kits
PiMPx Install question - Ford Truck Enthusiasts Forums
V8 Swap and PiMPx install - Ford Truck Enthusiasts Forums
Old Jan 15, 2021 | 04:30 PM
Sam Rogers's Avatar
Sam Rogers
Thats even more expensive than just getting a quarterhorse. I'm positive it's an EEC not an OBD but I'd wrather just buy a quarter horse than buy a whole new ECU. I just want to know if I could buy a OBD tuner and make it work on my truck instead of going with the binary tuner route.
Old Jan 15, 2021 | 04:49 PM
rla2005's Avatar
rla2005
If there is a data link inside the cab, center of the dash, you have a truck with OBD-II/EEC-V. If the data link is under the hood it's OBD-I/EEC-IV. There is not a lot of extra HP/TQ left under the table to be honest. A tuner will not net you that much for the money spent IMHO. The factory torpedo converter is an effective bottleneck. The factory EFI heads are very restrictive as well. The factory cam is actually not bad.
This thread will reveal there is power to be gained from a set of headers and a very knowledgeable cylinder head expert: https://www.ford-trucks.com/forums/9...ts-are-in.html
Old Jan 15, 2021 | 04:56 PM
wwhite's Avatar
wwhite
It is Electronic Engine Control (EEC) with On Board Diagnostics(OBD), probably EEC-IV(version four) with OBDI(version one), and if it is a California truck probably EEC-V(version five) with OBDII(version two).
Hard to say without looking directly at the hardware.
No OBD tuners that I know of will allow you to tune. You will need another computer(PimpX) or a piggy back, like Quarter Horse(QH).
Some can identify your computer from the 'Calibrations' sticker near the VIN plate in door jamb.
Another way to tell, is looking at the drivers side windshield post while door is open, there may be a 4 digit sticker that will 'help' identify the computer, if it is still the stock original.
Or, pull out your EEC and visually look at the sticker identifying the hardware. Probably Speed Density, and yes you can tune it with the right hardware and software.
Hardlanding
Mar 14, 2016 04:04 PM
bansheeduner
Nov 7, 2007 03:42 PM
emain879
Apr 23, 2007 07:35 AM
bobdog
Jan 16, 2004 05:23 PM
Skeetkiller
Electrical Systems/Wiring
Jun 14, 2003 04:00 PM
