Ran my truck last night
16.1 isn't all that bad strick88. If I were you, I'd switch to a Diablo chip first chance I got. Tomlongo bought one and it took .4 of his quarter time. From there, he proceeded to take about 2 seconds off. That's why I'm getting one. It's only like $230 too!
70mm KKB Throttle body
Spacer
Bassani cat-back
Also, you could go with the 4.10 gear drop and limited slip diff.
or pulleys, fans, rockers, gears
ie: pulleys and fans are expensive and don't give you very much power in the end. They also rob you in ways.
Here are some sites:
www.motorhaven.com <--great site!
www.seffects.com
www.rpm-mustangs.com
The last two are strictly for Mustangs, but you can still order parts for their 3.8 to fit your engine. (the 4.2)
Spacer
Bassani cat-back
www.seffects.com
6. Registration
6.1 No children 13 years old or younger may participate or register as a member of our forums.
6.2 You agree not to register with false or misleading information.
6.3 We reserve the right to reveal your identity to involved parties
or to a legal authority in the event of legal action arising
from any message you post or complaints arising from violation of these guidelines. We reserve the right to remove anyone from our forums for any reason, with or without prior warning.
6.4 If your posting privileges are revoked any attempts on your part to re-register an additional user id or email address will be
considered harassment and trespass.
6. Registration
planning on it
[QUOTE]Originally posted by true4.2
[B]16.1 isn't all that bad strick88. If I were you, I'd switch to a Diablo chip first chance I got. Tomlongo bought one and it took .4 of his quarter time. From there, he proceeded to take about 2 seconds off. That's why I'm getting one. It's only like $230 too good advice, I was planning that with my income tax,I just think its a better chip than the superchip, Maybe when I go back to the track I will do better with 93 oct, and its got alot colder here, I think the 15s are with in my reach.....
Strick88,
You've got me beat. 17.070 was my best so far....but on that run I burned rubber for a half a second at the start. I got those Kumho Ecsta's coming in which will get me into the 16's. You single cab stick shift guys got it made, try getting my hump back whale to move. When I first got it, stock?????? 20+ in the quarter. talk about slow! Fagetaboutit. Managed to knock over 3 seconds off so far and still going. I should have those tires in this week, hopefully before Friday. If I do, I'll take it out again on Friday and see what the sticky stuff does for me.
Tom
Tom
[QUOTE]Originally posted by tomlongo
[B]Ah yes, that cold northern air certainly helps in times. It's still 85 degrees down here at night with about 90% humidity.
Also, Strick88, try running the 113 racing fuel they sell at the track, after you get your chip. I usually put $5.00 in before I start running ---------------------------------------------------------------------------------- Do u think the diablo is that much better than my superchip, also is that octane stuff in the bottle any good
