some progress on my '56 Panel, sorta
Old Jan 4, 2021 | 12:14 PM
thomc's Avatar
thomc
Talking some progress on my '56 Panel, sorta
This morning I removed the Dodge car rear from the bent & broken frame that was under the '56 F100 that I got hit in back in July of 2017. The '69 Charger (I was told, it was out of the donor car when I got it) worked well under the pick-up. The gear is 2.76. I changed that after I installed it. It was originally a little low but I found a buddy with a Mopar that was automatic and he was swapping in a 4 speed so we traded punkins. I replaced the axle bearings at the time. Next I will remove my 500ci Cadillac engine from the chassis and whatever parts from the Volare IFS that I want to keep for spares for the Panel truck.
The spring & shackle bushings were replaced as were the shocks when the rear was put under the pick-up. The springs were disassembled, painted, lubed, and reassembled. Looks like the springs need rebuilding again.
Old Jan 15, 2021 | 11:01 PM
Oldb's Avatar
Oldb
Any progress is good progress. Good job.
B
Old Jan 16, 2021 | 09:51 AM
EBEAR's Avatar
EBEAR
Yup sometimes it only takes a little start to get the interest back .
Old Feb 19, 2021 | 06:04 PM
thomc's Avatar
thomc
I inventoried some of my parts since I hadn't seen most of them in almost 20 years, while the Panel belonged to someone else and I couldn't remember what was there and the condition was. Heck my memory is to the point I can plan my own surprise party and hide my own Easter eggs! I was pleased with what I found, mostly.
I think I can save the tank, with a new sending unit. I want to use the original gauge in the dash. Edit- Now I'm informed that this is not the Panel truck tank. I'm hoping that maybe the tank is still under the Panel. I'll find out tomorrow. I thought this was the tank I took out 20 years ago, maybe not.
The running boards are solid except for the holes in the center. I can fix them. They're not even all flattened and banged up on the outside edges like most seem to be! And I have the Panel only r.b. supports. Does anybody supply patch material with the correct ribs? If not I might still have the boards off my wrecked pick-up I can cut patches from if the ribs & valleys are the same size.
The replacement rockers that I had with it when I sold it didn't store well. I think I can de-rust them and they'll be ok though. My helper thinks we can save them.
thomc
Dec 26, 2019 09:53 PM
thomc
Mar 6, 2019 03:08 PM
thomc
Aug 29, 2018 06:28 PM
thomc
Jan 22, 2018 07:57 PM
Fomoko1
23
Sep 12, 2007 10:32 PM
