Oil capacity
Old Dec 23, 2020 | 09:15 PM
jernigan's Avatar
jernigan
Oil capacity
All right guys don't think I am a dummy for asking this. I have a 90 model f 150 5.0 auto 4x4. I have a 99 explorer 5.0 freshened up and ready to go in, I used my oil pan from the old engine as well as the dipstick. I just put a new filter motor craft fl1a and 6qts of oil in it. I used a drill and a long extension with a 1/4 inch socket and primed my oil system had a gauge in the sender hole and had almost 60 psi. Now I can check the oil and it shows 1qt low even after sitting over night. What could be going on?
Old Dec 23, 2020 | 11:10 PM
88n94's Avatar
88n94
Did you also use the dipstick tube from your old 1990 engine? At any rate after adding 6 quarts with no leaks, where the oil level sits now should be considered your full mark.
torq'ta 5 8's Avatar
torq'ta 5 8
Is the dip stick tube, same length, in same location on the 2 motors, some were in block, some were in pan
Old Dec 24, 2020 | 07:38 AM
jernigan's Avatar
jernigan
Yes dip stick and tube and pan from old engine. When I got the truck a few months ago it was not running and the previous owner had redone that engine at some point. So I dont know if it had the correct pan and dipstick in it.
Old Dec 24, 2020 | 07:40 AM
jernigan's Avatar
jernigan
Tube is in the block on both, my explorer engine had the tube broke off when I got it, so I used the one that came with the truck.
Old Dec 24, 2020 | 08:51 AM
timbersteel's Avatar
timbersteel
Sounds about right.
You poured in 6qts, primed the oil pump, the filter pressured and full, new engine that hasn't seen any oil before, and a quart low.
Add another quart and mark the dipstick.
Old Dec 24, 2020 | 09:41 AM
Scndsin's Avatar
Scndsin
The Explorer pan is a big cast aluminum thing. Got a 96 short block on the floor of the shop. Dip stick through the rail like all late SBFs.
Would suspect the sticks are different from truck pan to SUV pan.
So you should be good.
Baxtjh
Mar 12, 2010 05:20 AM
millerdog
Jan 18, 2010 09:55 PM
seneca
Nov 25, 2005 07:40 AM
bachelor
Nov 6, 2005 10:11 AM
bassin99
Feb 19, 2003 08:14 PM
