disc brakes
Old Dec 15, 2020 | 11:56 AM
vidaliaman's Avatar
vidaliaman
disc brakes
alright disc brakes guys, my local salvage yard is rounding me up a full disc brake setup from a 73-79 for my 68 ranger 5 lug, can you all provide me with an inventory list of what i need? thank you!!!
Old Dec 15, 2020 | 12:27 PM
Pcmdub's Avatar
Pcmdub
This has been covered a few different times but here is a quick list. If you need more info, do a search.
IBeams, knuckles, brakes, and rotors
Trailing arms, steering links
Also need to get the brake lines and brake line mounts for the frame.
Differential valve from the frame, and the two brake lines that go from the valve to the brake line mounts on each side of the truck.
Then, core exchange the calipers for some new ones with pads and new rotors, seals, and bearings.
Good luck
Old Dec 15, 2020 | 12:43 PM
vidaliaman's Avatar
vidaliaman
awesome, i see ibeams, so i would need to discard the ibeams on my 68?
Old Dec 15, 2020 | 02:32 PM
Coastal68's Avatar
Coastal68
Hyperlink page with threads on disc brake swaps: https://www.ford-trucks.com/forums/1...mpilation.html
Old Dec 15, 2020 | 03:51 PM
vidaliaman's Avatar
vidaliaman
shoot, the only page i can't bring up is 65-72 PS & Disc Brake Swap
Old Dec 16, 2020 | 01:45 PM
vidaliaman's Avatar
vidaliaman
i'm just a bit confused, can i use my 1968 ibeams or do i need the ibeams from the 73-79 ford?
Old Dec 16, 2020 | 03:23 PM
RichS2659's Avatar
RichS2659
IIRC you have to change the 68 spindles to the 73-79 spindles and mess with the king pins. It is easier just to swap the 73-79 beams over without messing with the hassle of changing the spindles and king pins.
Old Dec 16, 2020 | 03:27 PM
vidaliaman's Avatar
vidaliaman
got it, the spindles are pretty rusted on the 73-79 donor, i can clean that up, is that a concern?
Old Dec 16, 2020 | 04:36 PM
Mikulh's Avatar
Mikulh
UltraRanger did a great write-up...link below
https://www.ford-trucks.com/forums/1...ont-drums.html
Old Dec 16, 2020 | 05:46 PM
vidaliaman's Avatar
vidaliaman
that is going to be helpful, thanks
Old Dec 17, 2020 | 10:24 AM
351Cleveland C4's Avatar
351Cleveland C4
I don't know why everybody says you need the brake line brackets. The original ones on my 71 worked just fine. I don't see a reason why you would need to change them.
Kingcw1966
Dec 18, 2020 04:48 PM
vidaliaman
Dec 4, 2020 04:22 PM
Rubiranch
Mar 17, 2006 06:37 AM
bassproguy07
Dec 14, 2005 10:12 AM
